Moisture in tail light
Old Mar 30, 2016 | 08:39 PM
elee3's Avatar
elee3
Today, I noticed some moisture in my drives side tail light lens. Has anyone had an issue with this? Of course I'm a few months past the bumper to bumper warranty.
Old Mar 30, 2016 | 11:10 PM
Iowa Ford's Avatar
Iowa Ford
Lee, I have one like yours, but no moisture yet.....
Old Mar 31, 2016 | 01:38 AM
Dakster's Avatar
Dakster
Can you post a picture?
Old Mar 31, 2016 | 08:08 AM
SavageNFS's Avatar
SavageNFS
One way to get the moisture out is to remove the tailight one evening. It's just two screws if I recall. Unplug the bulbs and bring it inside. Get an old pair of nylons from wifey. You want to make a bag that will fit in the holes of the bulbs in the tail light out of the stockings. Not too big, but large enough to fill with rice. Tie off the top with string and leave the string long enough to tie a large washer or pencil to the bag doesn't get trapped into the housing. Let sit overnight. Rice should absorb all the moisture in the light. Once all the moisture is out. Look for a seam or crack letting it in and seal it up with silicone tent sealer. It's UV resistant and a stronger type glue. You can also buy a small tube rather than a caulk tube type canister. Just my advice. Good luck.
Old Mar 31, 2016 | 11:13 AM
scraprat's Avatar
scraprat
Top Answer: 5
Why worry about it unless it's literally holding measurable amount of water. I've seen moisture in all my Super duty rear lights at the bottom after washing the trucks never gave it a thought.
Old Mar 31, 2016 | 08:47 PM
elee3's Avatar
elee3
Just got home and watched the video on how to post pictures. Hope this works.
Old Mar 31, 2016 | 08:50 PM
elee3's Avatar
elee3
Thanks Savage, good idea.
BTW. anyone know why my picture is so big?
Old Mar 31, 2016 | 08:53 PM
elee3's Avatar
elee3
Call me crazy, but as much as these trucks cost, I expect them not to leak 3 months after the warranty expires.
Old Mar 31, 2016 | 09:23 PM
Dakster's Avatar
Dakster
That's too much in my opinion.
That's why I asked for the photo. I have some but it goes away quick.
Old Mar 31, 2016 | 09:48 PM
scraprat's Avatar
scraprat
Top Answer: 5
Ditto, That's why I said why sweat it.
Old Mar 31, 2016 | 09:51 PM
scraprat's Avatar
scraprat
Top Answer: 5
Originally Posted by elee3
Call me crazy, but as much as these trucks cost, I expect basic them not to leak 3 months after the warranty expires.
I certainly wouldn't call you crazy. It's moisture in plastic hurting nothing or you didn't say it was causing a problem other than you knowing it's there.
Old Mar 31, 2016 | 10:25 PM
elee3's Avatar
elee3
Not causing any problem yet. I just noticed it after we had 4 straight days of rain. Here in FL, stuff will start to grow in there if I let it go too long. Probably will work on it this weekend.
I will report back when I figure out where it's leaking.
Old Apr 1, 2016 | 12:49 AM
Dakster's Avatar
Dakster
You'll have fish in their in a week... (I know, I lived there for a long time)
The heat from the bulbs in my taillights burn off whatever builds up in mine.
FWIW, GM gave up on keeping moisture out, they have holes in the bottom of their taillights. No saying you should drill holes in the Ford ones though!
Might show that to your dealer and see what they say.
Old Jan 8, 2018 | 07:17 PM
RSGreen's Avatar
RSGreen
Lee,
I know this is a pretty old post, but I have a 2015 F250 with almost the exact same problem. The moisture in the clear portion of the back-up light in my passenger tail light is nearly identical to your photo. Did you figure out a solution to the moisture issue? I tried to silicone the edges of mine but it didn't resolve the issue.
thanks!
Randy
Old Jan 8, 2018 | 08:04 PM
elee3's Avatar
elee3
Randy,
Sorry, but I ended up trading this truck in for a 2016 about 3 weeks after this thread. I never came up with a solution. The trade had nothing to do with the moisture.
