$3100 Quote to Repair - Please review
Old 03-30-2016, 01:24 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
Received 1,206 Likes on 829 Posts
Originally Posted by beeper212
I took my 2002 Excursion 7.3L w/ 180K miles into my local Ford dealer for an intermittent battery light. This has been a problem for several months but finally resulted in the truck not starting. Running voltage at the cigarette lighter was 13.2 - 13.5v.
Just a got a call from their service department and here is what they are telling me needs to be repaired (parts and labor):
alternator $640
bump stops front $275
bum stops rear $165
oil leak from intake tubes $430
engine air filter $49
shocks front $365 (rusted out)
rear shocks $310 (rusted out)
fuel filter $128
Additionally they said that my 'hubs are frozen' and if I lose my vacuum I will be unable to shift between 2WD and 4WD. Its currently working but if I wanted to fix this it would be $775.
Which of these line items stand out as being excessive in price?
What questions / requests should I be making?
Any other advice that you would recommend?
Sorry I'm completely incompetent!
Thanks in advance,
Beeper
All seem over priced, holly cow what the rest said, I would recomend to do the work yourself in the end you will feel alot better working on yoir own rig and not some person that for all you know he may not do what the invoice said.
Old 03-30-2016, 01:49 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Originally Posted by Walleye Hunter
...one thing I'm seeing that was not addressed is the voltage at the cig lighter of 13.2-13.5. I do not see the alternator being a problem with this kind of voltage there. Am I wrong?
The voltage indicated at the cigar lighter may not be an accurate measurement of the actual charge voltage (at the battery.) Assuming it is representative, way too low and would soon result in failure due to a discharged battery.
Typically somewhere in the 14.x to 15.x volt range is required depending on the state of battery charge outside temperature, accessory loads etc.
Old 03-30-2016, 02:29 PM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
Yeaaaa, I understand that but mine is running 13.5 or so and has been for about a year and it holds it when loaded up with A/C, full fan and headlights. I know it's not 100% but it has not stopped my truck from running. It could be part of my not so easy to start when the temps are under 15 though but I'm one who's good for pushing these things.
Old 03-30-2016, 02:41 PM
andym's Avatar
andym
andym is offline
When I'm idling at a stoplight with both front & rear AC going full blast, mine drops to under 13. As soon as I start moving again, I get about 13.5 to 13.7. If I shut the AC off, it's 14 or a little more (I think... I will have to double check my numbers)
Old 03-30-2016, 02:55 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Are you measuring at the battery posts? What are you using to measure? Accuracy is important when it comes to batteries.
Battery theory and technology was sussed out almost 100 years ago so there's no guess or by golly here. 13.2 volts is basically a "float" charge voltage there's no way it will replenish a start battery or keep up with vehicle and accessory demands. Remember the battery has only one main function - start the engine. It is the alternator's job to provide for the ignition and accessories. Many people are confused about the role of the battery and alternator, people who should know better.
Any battery needs to see about two (2) volts above and beyond the resting open circuit voltage (OCV) in order to approach a full charge at 70F and more, as the temperature goes down. This is because the internal resistance increases.
A maintenance free sealed battery is 100% charged at 12.8 volts so, in order to reach a full charge close to 15 volts is required. Batteries "like" to be held at this voltage for a while as well. A slight overcharge above these figures tends to equalize the cells and is considered beneficial. It is possible to overcharge a battery but it takes real dedication.
Chronically undercharged batts will start the engine, they just typically crap out after a couple years and probably roast the alternator and other components. Vibration and heat play a role, but in comparison stationary batteries kept in a good state of charge can last 20 years or more.
Old 03-30-2016, 03:10 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Again this may not be an accurate measurement. Many people report for example using a scangauge that the voltages at the OBDII port are low by about a half volt or more. But it sounds like excessive sag all things being equal.
The important thing to always keep in mind when dealing with batteries and charging is to first get ACCURATE numbers to work with, this means measured at the battery posts, or compensated/adjusted figures at least.
A tenth or two of a volt either way doesn't sound like very much but it really is. Further, it also needs to be adjusted or compensated for temperature.
Next is to get all of the charging capability you paid for. Even barely measurable amounts of ohms resistance in the high amperage charging circuit will cripple any alternator!
You can test for this quickly and easily using a voltmeter without disconnecting anything.
http://www.aa1car.com/library/voltage_drop_testing.htm
"It doesn't take much of an increase in resistance to cause trouble. Let's say a 120 amp alternator operates in a circuit that has a normal resistance of 0.11 ohms. If that resistance were increased to 0.17 ohms because of a bad wiring connection, the alternator's maximum output would be limited to 80 amps. In other words, an increase of only 0.06 ohms (almost nothing!) would reduce the alternator's maximum output by almost a third! Under light load, the drop in charging output might not even be noticeable. But in a high load situation, the alternator wouldn't be able to keep up."
Old 03-30-2016, 04:04 PM
beeper212's Avatar
beeper212
beeper212 is offline
Wow! You guys are awesome. I will hold off on the dealership and reach out to an independent mechanic and also see what the Virginia forum has to offer.
Thanks again for the info and I will keep you updated.
Beeper
Old 03-30-2016, 04:14 PM
Tugly's Avatar
Tugly
Tugly is offline
Recent alternator, new batts, headlights only - 13.9 to 14 volts on the highway. 12.5 volts with glow plugs off.
Old 03-30-2016, 05:50 PM
jetdoc's Avatar
jetdoc
jetdoc is offline
I'm just north of Annapolis if you're close....
Old 03-30-2016, 05:56 PM
beeper212's Avatar
beeper212
Any suggestions on brands and models I should look for the alternator, front shocks, rear shocks, serpentine belt?
Are their any other 'easy upgrades' that you'll might suggest?
Thanks,
Beeper
Old 03-30-2016, 06:24 PM
binuya's Avatar
binuya
binuya is offline
Thanks,
Beeper
If you have a reputable local auto electrical shop, I would suggest you take your alternator in to have rebuilt. Most of the big box store alternators are imported production line rebuilds. You stand a better chance of getting higher quality internals from a rebuilder. A couple years ago on a trip to Yellowstone our alternator failed and I wound up having to buy one from O'Reilly's to get our family back on the road. What killed me was giving up the dead Motorcraft stamped core. Given the time and situation, I would've greatly preferred to have that one rebuilt. The one I got has been working fine, but I don't have as much faith in imported parts as I do domestic.
Old 03-30-2016, 09:05 PM
schlepprock250's Avatar
schlepprock250
schlepprock250 is offline
We had an alternator fail while on the road last summer. I had to get an oriellys alternator but paid a $30 cash core charge so I could keep my og stocker.
  #28
Old 03-31-2016, 07:28 AM
Tugly's Avatar
Tugly
Tugly is offline
Thanks,
Beeper
I'm not one to suggest something on a whim, it's helpful if I know some specifics. What is your comfort level...
  • under the truck or on a step ladder while leaning over the fender?
  • with hand tools like socket sets and allen wrenches?
  • with getting your hands/clothes dirty?
  • with getting directions from a forum to perform a task in the truck?
I know people who would never pick up a screwdriver, let alone a torque wrench. I also know people who have their own shop and enjoy wrenching on the weekends. Most of us are somewhere in the middle - I'd guess more like mechanically inclined, but we'd rather drive than wrench.
  #29
Old 03-31-2016, 09:34 AM
Syncrowave's Avatar
Syncrowave
Syncrowave is offline
Originally Posted by Dan V
Bump stops? Honest God, they said that?
Yeah, I choked on my Wheaties on that one too.
How many hundred dollars to air up the tires?
  #30
Old 03-31-2016, 09:46 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Silly rabbit. It's NOT just air being installed in those tires, but an organic gluten-free nitrogen.
Quick Reply: $3100 Quote to Repair - Please review
