E40D Code 634
Old Mar 28, 2016 | 06:28 PM
alf15092's Avatar
alf15092
E40D Code 634
So back last April I started having intermittent hard shifts. I ran the code myself and 634 came up (MLPS voltage higher or lower than expected). The shop I took it to ignored that and ended up replacing the solenoid pack, which solved the problem until this past June. It shifted hard up until November, then it was fine until now when the temperature outside is warming up, it is always fine in cold weather. I ran the the codes today and the same 634 came up. Can this be the cause for hard shifting? why would the temperature outside matter? This is a 1992 F150 302 with 185K miles 4x2 supercab. It runs great otherwise, so I would love to get this figured out. Thanks!
Old Mar 28, 2016 | 06:47 PM
Lead Head's Avatar
Lead Head
Yes it could most certainly cause hard shifting. Sound like the shop just wanted to cost you money if they ignored the MLPS code. The MLPS is relatively cheap, and pretty easy to change. You don't even need to open the transmission up.
blue924.9
Oct 7, 2014 04:22 PM
triskadek
Escape & Escape Hybrid
Mar 8, 2010 03:49 PM
frnkln2003
Feb 10, 2008 08:43 AM
cool guy
2004 - 2008 F150
Aug 5, 2006 12:02 AM
stevieray
Feb 18, 2002 11:45 AM
