Instrument panel wiring help
Old Mar 28, 2016 | 10:51 AM
Bigred1971's Avatar
Bigred1971
I just bought a new wiring harness and the plug that came with it is arranged wrong if any body could help me put it in the right order or just has a schematic to show where everything goes that would be great
Old Mar 28, 2016 | 11:14 AM
ultraranger's Avatar
ultraranger
The '71 wiring schematics aren't listed but, you might be able to go by the '70 or ''72 schematics to figure it out.
Ford Truck Technical Drawings and Schematics - Section H - Wiring Diagrams
Old Mar 28, 2016 | 11:26 AM
Freightrain's Avatar
Freightrain
Go figure, the "other site" doesn't list a 1971 wiring harness.
If you want to just cruise and and see what you can find:
(guess I was typing too slow and Ultra beat me to it)
Old Mar 28, 2016 | 12:53 PM
hillcountryflt's Avatar
hillcountryflt
You might mention any details about your harness - brand/model/etc.
I am pretty sure 71 and 72s were pretty much the same under the dash, not sure about 70. I know 68 and 69 were the same.
Old Mar 28, 2016 | 02:10 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1970 F100/350 & Econoline use ONE YEAR ONLY Printed Circuit Boards, with or without Oil/Amp Gauges.
1971/72 F100/350 use the same with or without Oil/Amp gauges Printed Circuit Boards, that are also the same as 1971/74 Econoline.
Old Mar 28, 2016 | 03:26 PM
Bigred1971's Avatar
Bigred1971
This is the layout that I received the plug in and the diagram that it's supposed to be in finished
Old Mar 28, 2016 | 03:39 PM
hillcountryflt
Mind if I ask where you obtained that connector? I could sure use one for when I swap in my f600 instrument panel that uses the older style connection.
Old Mar 28, 2016 | 03:47 PM
Bigred1971's Avatar
Bigred1971
The connector came with the Centech wiring harness I just bought
Old Mar 29, 2016 | 06:44 AM
hillcountryflt
Thanks, been wondering about the centech wiring harnesses.
Old Mar 29, 2016 | 04:04 PM
BobbyFord's Avatar
BobbyFord
Doesn't follow '72 wiring at all. I'm guessing it isn't for '71 either.
C10 connector is the instrument cluster connector. Wire numbers and color codes are listed---> http://www.fordification.com/tech/wi...ing_legend.jpg
hillcountryflt
24
Jul 13, 2016 03:52 AM
bigdavesohc
13
Mar 6, 2011 10:21 AM
yetiman
Mar 24, 2009 05:09 PM
footballmac
Mar 12, 2007 12:51 PM
red75
Electrical Systems/Wiring
Feb 26, 2004 09:47 AM
