Brake line replacement
Old Mar 28, 2016 | 06:16 PM
Shane Carruth's Avatar
Shane Carruth
Thank you all for your input, it's been very helpful. Inline66 when you routed your new brake lines did you put them back behind the steering box?
Old Mar 28, 2016 | 06:42 PM
ultraranger's Avatar
ultraranger
I have a friend who has a '65 F100. He installed DJM lowering beams/rear shackles and the front disc brakes from a '78 F100/F150. Like any '65 F100, his truck originally had the single reservoir (suicide) MC on it.
He brought it to me for me to plumb the hard lines between the front wheels and to install a tandem MC and to plumb it to split the front brakes from the rear.
Last year, the truck was stripped completely down and the frame and the body were repainted. These photos are from back when I did the brake plumbing on it and before the rest of the truck was redone.
Old Mar 28, 2016 | 07:01 PM
Shane Carruth
So that is a no on routing behind the steering box?
Old Mar 28, 2016 | 07:08 PM
markeyd's Avatar
markeyd
Originally Posted by Inline66
Markeyd, how much difference did you notice between the manual and power drums? I was thinking about adding a power booster to mine.
It was a very big difference, and I used a very small booster . . . not a dual diaphragm either. (This is because I have no plans to go with discs, and drums are much more efficient . . . I did not say drums are better, discs are arguably better in many respects, but drums are more efficient in the sense that they require a lot less force to work, i.e. less pressure to work). The less powerful booster was enough, and it would take a lot more power to stop discs. (Discs stop on a dime, and you have a lot of control, have many other advantages too, but simply require a powerful booster to work well).
That being said I replaced everything . . . drums, shoes, MC, wheel cylinders, hoses . . . everything after the brake pedal. Now it stops on a dime and gives you back 9 cents change. Its hard to tell how much of a role the various components played, but I did test the booster with the old drums, shoes, and wheel cylinders and it was a huge difference with just the booster, new hoses, and new lines. Now, I gently press my foot on the pedal and slow down at a light, . . . give some more gentle pressure and come to a complete stop. It wasn't like that without the booster. Also, if I slam on the brakes on dry pavement I skid to a nice straight stop.
You may as well add it. The only other thing you'll have to buy is the firewall bracket, booster, and maybe a threaded adjustable push-rod that hooks up to the pedal. I bought that in a kit with the Master Cyl., and prop. valve and had everything I needed except line and fittings. (plus the hoses, and other parts mentioned if you are replacing those as well). You can buy it all separate though.
One disadvantage to drums is that they lose effectiveness when they heat up. They'll heat up in stop and go traffic. Also, if they get wet in the rain and trap moisture they lose effectiveness. I drive my truck in the country, on sunny days so drums work very well for me. It's not a daily driver so I do not want to invest in a disc conversion right now.
If I were still in the city I would go with discs.
Good luck!
Old Mar 28, 2016 | 07:20 PM
markeyd's Avatar
markeyd
The kit I bought looked something like this:
Old Mar 28, 2016 | 07:32 PM
ultraranger
On my friend's '65 F100, I ran the lines from the MC and down in the corner of the engine compartment, where the firewall and the inner fender apron meet. They came out behind the steering gear box, just like the original line did.
If you're fabricating your own brake lines, you can route them however you want to get from point A to point B. It's just best to keep the lines as far away as possible from extreme heat sources like exhaust manifolds or headers.
Old Mar 28, 2016 | 07:47 PM
Shane Carruth
Yeah, I figured I can route them how I please. The stock lines made a bend to go between the steering box and frame to meet up at the distribution block. With the 3 port tee, I was thing of running the line around the outside of the steering box down along frame to the passenger side.
Old Mar 28, 2016 | 07:59 PM
ultraranger
I had a manual steering gearbox in my '69 F100 but replaced it with a Saginaw PS gearbox. At any rate, both had the same 3 bolt mounting pattern. You can take the top bolt out of your steering gearbox and then just back the other two bolts off. After that, you can pull the steering gear box inward towards the engine and it will open up a gap between the box and the frame rail.
You would be able then to lay your brake line into the indented slot, between the box and the frame then, put your bolt back in and tighten the gearbox back down.
....or, you can run the line outside the gearbox. It's just up to you.
Old Mar 28, 2016 | 09:22 PM
Inline66's Avatar
Inline66
I also ran them like Ultraranger described. I used the stock distribution block in the same location. The rear line ran down near it and then curved toward the rear. Btw, great write up Ultraranger, that clears up a lot for me. Come to think of it, you're probably the guy that I mentioned telling me about residual valves and newer wheel cylinders.
Markeyd, I'm definitely adding this to my list. For some reason I had decided to just stick with manual until I eventually did the disc upgrade, but why not go power drums? Everything else is already new, so it can only help.
Old Mar 28, 2016 | 10:07 PM
Inline66's Avatar
Inline66
Looks like this would be all I'd need: http://m.ebay.com/itm/321937747242
I think that MC has a spot for the brake light switch too. Shane, you might want to consider something like this too if you're already doing the work to swap the MC.
Old Mar 28, 2016 | 10:14 PM
ultraranger
I had previously mentioned that my '69 F100 came with manual 4-wheel drums and that I had later changed over to power front disc brakes. What I didn't mention was that in between this, I had the power brake booster I have now with a conventional cast iron 1.00" bore MC and all-wheel drums. --I figured the brakes would be sensitive with this configuration and I was right.
This was in 2012 when I installed the '75 F350 booster but still had drums all the way around.
Manual brakes generally have around a 6:1 pedal ratio (mechanical advantage) while a typical power brake setup would be around 4:1. The pedal ratio didn't change (reduce) when I went from manual brakes to power brakes. The booster input rod was a straight, direct connection to my stock '69 brake pedal.
'67 and earlier F100s had 11" x 2" front drums and 11" x 1-3/4" rear drums. In '68, Ford upped the front brakes to 11" x 3" and the rears to 11" x 2-1/4". This was a lot more surface area and with the dual diaphragm booster and the 1.00" bore MC and no change in the pedal ratio, the brakes were pretty sensitive.
When I went to discs, I knew if the pedal ratio couldn't be changed (move the connection point of the booster input rod lower on the brake pedal, further away from the brake pedal's pivot), the only other way around this was to go up in MC bore diameter so, I installed a 'modern' 1-1/16" bore MC. A smaller bore MC will produce more output pressure, for the same amount of force applied to the brake pedal, than a larger bore MC. Going up 1/16th of an inch in MC bore diameter (above a 1.00" bore MC) equals a 6% reduction in output force to the brakes. But, with the powerful dual diaphragm booster behind it, the balance on my truck's brakes are just right.
Now, the brakes respond really well and brake modulation (linear application of brake force) is excellent. This is where drum brakes don't 'shine.' Modulation isn't good with drums because of their duo-servo, self-energizing nature.
Old Mar 28, 2016 | 10:19 PM
ultraranger
Looks like this would be all I'd need: 1957 1972 Ford F100 8" Brake Booster 1 1 8" Bore Master Cylinder w Brackets | eBay
A single diaphragm booster with a 1-1/8" bore MC is likely to equal a brake system with a rock hard brake pedal and you would likely find that it's very difficult to get the truck to come to a stop within a reasonable distance.
A 1-1/8" bore MC would have nearly a 13% reduction in output pressure for the same amount of force applied to a brake pedal with a 1.00" bore MC.
--personal opinion here but, I'm not keen on the Corvette MCs used in those kits.
Old Mar 28, 2016 | 10:23 PM
  #28
Inline66's Avatar
Inline66
What if I used that type booster with the 1" MC I already have? This is with the smaller 66 drums.
Old Mar 28, 2016 | 10:57 PM
  #29
ultraranger
I've been fooling with brake systems for nearly 30 years. Everything from just your basic service work on all-wheel drums to doing front disc brake conversions or 4-wheel disc brake conversions. I designed, produced and sold 3 different rear disc brake conversion brackets for about 14 years to put later model Ford rear disc brakes on vintage Mustangs and related Fords, using '84-'90 Lincoln Mk VII rear discs, '94-'04 SN95 Mustang V6/GT rear discs and '94-'04 Cobra rear discs. I don't claim to be an expert but I've had a lot of practical, hands-on experience at this.
It's been my observation that RARILY does an aftermarket brake booster perform as well as an actual OEM Bendix brake booster, even if it's a rebuilt unit like the Bendix booster I have. There were also single diaphragm Bendix boosters for Ford trucks.
Here's a couple on the left and one on the far right (the two in between are dual diaphragm units). Left to right: ' 68 F250 single, '74 F100 single, '74 F350 dual, '74 F350 dual, '78 F150 single.
Hard to say what the outcome would be with the aftermarket booster and the 1.00" bore MC. That's just the nature of 'engineering' a brake system (or anything automotive). Sometimes it works out fine, sometimes it doesn't. That's when you have to spend the time (and the money) to swap parts around until you get something that works to your satisfaction of being acceptable in what you expect out of it.
Old Mar 29, 2016 | 07:44 AM
  #30
Inline66's Avatar
Inline66
Thanks again for all the info. Shane, hopefully all this is helpful to you too.
