Tranny heating up
Old Mar 28, 2016 | 10:08 PM
dbny111's Avatar
dbny111
Originally Posted by Tom
Check the transmission temperature after a long cold soak. After sitting all night the transmission, EOT, and ECT should all be within a few degrees of each other. If the transmission temp is more than a couple of degrees off you may have an issue with the circuit or the sensor.
How can I check that myself? Do I need a scan tool hooked into the pcm to get those readings?
Old Mar 28, 2016 | 10:10 PM
Tom's Avatar
Tom
If you have the 4.3" LCD screen in the instrument cluster you should be able to see oil temperature(EOT) on the same screen as transmission temperature. Coolant temperature(ECT) is a generic OBD parameter that any OBD gauge can see. Think you mentioned something labelled "Coolant" on your mini maxx, that would be ECT.
Old Mar 28, 2016 | 10:17 PM
dbny111's Avatar
dbny111
Ahh sorry, didn't get the technical references but yes I've checked those. The oil and coolant are within a couple degrees and the trans reading is a few higher than those. Not sure if it's always been that way, I never paid attention before but they're all within a few degrees.
FiveOJester
2009 - 2014 F150
13
Jun 22, 2017 06:53 AM
r2millers
Jun 6, 2014 11:02 AM
Scornwell
6.4L Power Stroke Diesel
Aug 25, 2013 09:11 AM
vlietracer64
Sep 29, 2011 01:33 AM
mrad
Jan 15, 2010 12:51 PM
