Installing new seats that have memory, need help on getting power to them? 2006 Explorer
#46
Al working
The all green wire on C341B I spliced to the green/violet wire from C352 and it is working. Tried that wire since it was the only 1 left out that was the same gauge. I will work on heated seat tmrw. t/u again for all the help...
#48
-Rod
#50
#52
Rod can i pick your brain for a few moments
Rod
was hoping you could assist me in wiring up some seats.
I have a 1995 Chevy k2500 that im restoring. It has power seats in it now but they were put in by the previous owner and have seen better days.
I was able to procure a really nice set of leather seats from our local pick your part lot
They came out of a 2008 Lincoln mkx. I had to go back online to come up with this info. I'm 99% sure on this.
Ive tested the motors supplying them with 12 volts to make sure they all function. Which they do. But seats have come along way since I installed some quite a few years ago. I'd like to get the basic movements to function. I believe they have the heat function, which would be nice but not a deal breaker. Since i dont have a switch for that feature anyway.
do you have some free time to pull the schematics and tell me what wires need power and what wires need to be grounded out? The seats have air bags in them. Not that i will use them. I just didnt want to haphazardly start throwing 12 volts around and set the air bag off in my face.
If you have a few minutes, I would be appreciative.
If you want of need photos.. I can provide. Just let me know.
#53
There are several options for the front seats in a 2008 MKZ, so without having to pull schematics for for each of the types, hopefully you can narrow down which type you have. There are 6-way power, 8-way power, power with memory, and climate controlled. Do you happen to know which kind you have?
-Rod
-Rod
#54
-Rod
-Rod
Rod
Thank you so much for responding. I wasnt sure if you were still receiving notifications from this thread.
I was about to attempt to solder wires directly from the switch to the motors hopjng that might do the trick. And that may still be the case, but I'll provide you with the information youve requested and let you tell me the best course of action.
Also I was planning to head back to the junk yard and locate the seat heater switches and pull those along with there attached wires and im guessing there will be a relay most likely that is also on the switch wiring harness.
Anyway..to get to your question. Both the passenger seat and the drivers seat have three separate switches. The first switch is forward & reverse as well as raise the front of the seat up or down and raise the rear of the seat up or down. The second (or middle switch ) looks like it just controls the back part of the seat tilting it forward or backwards. The third switch appears to be the lumbar support and has two positions.
I have lots of numbers I can provide you with
The first being what i assume is the main module
Passenger seat
7L1T-14B663-BA
There's a couple other numbers on it but I believe thats the one which identifies it. It also says
MOD ASY - ST Cool/heat
The wiring harness is identified as Ford 7A1T
14A698
G2814
8/17/07
The main tag for the frame is labeled as
PN:8T43-7861700-AA PLT:19
The drivers seat info:
Module. 7T4I-13C789-AD
(Hard to read. But 98% sure)
Wiring harness:
7A1T
14A699
G2814
8/23/07
Seat Frame info
PN:8T43-7861701-BA. PLT:13
On the drivers seat. The switch housing has a total of 12 wires
In, I'll call it row one position 3 is a black wire which appears to be the common ground and position 5 is a green wire with a dark red (maroon) stripe which im assuming is the 12 volt power wire because these two wires interact with the remaining ten wires depending on which switch is being turned on.
If I can provide you with any additional information. Just ask away.
And I really appreciate you helping me sort this out. Schematics are like a foreign language to me. But I can use a multi tester and no problem soldering. I just never did much with actual circuits.
#55
It sounds like you have the 8 way power seats with climate control (heat and ventilation). I'm guessing that since you have all features they car also had memory seats. You'll probably want to bypass the memory function which, since you don't mind wiring/soldering, shouldn't be an issue. You'll need to bypass the seat modules.
I'd like to send you the wiring diagrams for the seats versus me trying to type everything out. I think Ford service manual wiring diagrams are pretty easy to read. If you have questions on them then ask, but I don't want to type everything out to start with.
Please send me a Private Message with your request and an e-mail address I can send the service manual screen captures to (JPEGs) as it's more than I want to upload to this thread as well (wiring diagrams and connector faces).
-Rod
-Rod
#56
-Rod
-Rod
I went into my account and tried to send a message but it wouldnt allow me to.
just send them to my gmail acc
Bteflorida@
Im sure you'll know the rest
Thanks again
#58
#59
2010 Raptor Power/Heated Seat Install Into 1978 F150
Hello Rod @shorod ,
Full disclosure - total newb here, might need to explain to me like I'm 7 years old - your efforts will be not only appreciated, but reimbursed appropriately. I literally know nada when it comes to these seats. DSM?? Where is that? or wiring in general. <<<That's about where I'm at. So I'll have a friend who does some wiring follow along later.
I visited a local Ford dealership and got the typical runaround about "THAT CAN'T BE DONE, LADY!"
I've been scouring the interwebs for help and came across this thread, thankfully.
Here's the short of it...
Donor: 2010 Raptor SVT Power/Heated seats (Driver/Passenger)
Vehicle: 1978 F150, single cab
I'm attempting to power the seats to set up for mounting in a comfortable position with very little adjustments in the future due to limited space. Would love to have the heated seats working as well. No need for memory. I got these seats for a killer deal and was told that they work perfectly.
Any idea how I would go about gaining these functions for the 78 build?
I bought what I thought were the correct body to seat harnesses but only one connector actually fits and I'm not even sure I need them. I can return them if I can just bypass these connectors directly with what I think you might be calling "jumper wires" and eventually make the connection correctly. It would be much easier for plug and play but I'll follow your advice here. I don't even know if i need to use these connectors??? Again, 7 years old.
If you have any diagrams that would help my friend (and me) to better view what's to be done, it would be greatly appreciated.
So I guess the right ask at this point, is how would YOU go about powering these? (I didn't see any 2010 references above). And how can I avoid setting off the airbags or completely disconnect them?
I can forward more pics if needed.
Thank you in advance for your time. Please send PayPal.
Nicole
(just a girl trying to relive memories after her father's passing, in a similar truck to his)
Nicole
#60
Are you pretty confident those seats came from a 2010 Raptor? The connectors on them don't seem to match up to what the factory service manual shows for 2010 Power Memory Seats or just Power Seats. If you're confident they're from a 2010 I'll do some deeper diving in the service manual, but wanted to check before I spent too much time looking in the wrong place.
The factory service manual doesn't break out Raptor specifically so I'm looking in the F-150 section.
-Rod
Memory seat connector C341B
Memory seat connector C369
-Rod
