I need some help/advice on replacing a part on my 91 F150 with a 5.8L motor. I have a coolant leak in the hose from the throttle body. There was a hole in the line. No problem getting the hose off (well other than one of the clamps was positioned where I couldn't loosen it but I eventually got it off). I went to both AutoZone and O'Reilly and neither of them seem to have this hose or anything that looks like it.
Questions:
1. has anyone else had to replace this little guy?
2. Were you able to get the part from one of the chain parts stores?
3. If you were not able to find it at one of the chains, what did you do as a workaround on this?
First time I have not been able to find a replacement part for this truck.
