02 AC compressor/clutch question.
Old Mar 24, 2016 | 04:08 AM
tjc transport's Avatar
tjc transport
i ain't rite
i have never taken one of these units apart, just replace the compressor.
my 02 has a 6 month old compressor on it.
the belt tensioner failed and threw the belt ripping the electrical connection off the compressor. the resulting carnage means the AC now does not work unless the connector is placed and held just rite.
if i replace the clutch will it also come with a new connector, or do i need to replace the complete compressor and clutch?
Old Mar 24, 2016 | 06:15 AM
projectSHO89's Avatar
projectSHO89
You have to replace the coil in order to replace the connector. It's not an in-place repair, the compressor needs to be on the bench in order to get the clutch puller attached, then the replacement coil has to be pressed onto the compressor housing.
You're probably ahead of the game to simply replace the whole loaded compressor (again) unless you're comfortable pulling the whole thing out and swapping the coil. The coil is about $45 from Rockauto. You can buy a complete compressor kit from Rockauto for $150.
Old Mar 24, 2016 | 04:15 PM
tjc transport
i ain't rite
ok, that is what i thought.
oh well, it's only money.
chdairy7
1997 - 2003 F150
Aug 6, 2011 05:55 PM
jimbo beam
Dec 12, 2009 05:17 AM
marragtop
May 29, 2007 09:09 PM
BHE
Mar 16, 2007 02:25 AM
ichiwawa2001
Nov 2, 2005 07:44 AM
