2008 Ford Expedition HELP.
Old Mar 23, 2016 | 08:06 PM
Rodjak's Avatar
Rodjak
Unhappy 2008 Ford Expedition HELP.
Hello all.
I have a 2008 Ford expedition that misfires and I am stuck on what to do next. Truck runs great when cold but when it warms up it starts to shake and badly misfire on idle and under light accelerations. If I give it a bit of rpm the misfire goes away and truck runs smooth again until I come to a stop or try to accelerate slowly then it again shakes violently and if in reverse it stalls out. No codes when hooked up to the scanner and no check engine light.
I changed all 8 plugs (Motorcraft) and all new coils. I also changed VCT solenoids on both banks and Camshaft timings sensors on both banks. Still truck runs the same when it warms up. When replacing the solenoids we inspected the timing chain, phaser and rails/guides and everything seemed good. The chain is not loose or skipped a tooth. Like I said everything seems ok. No noise from the phasers when running. Engine runs smooth when cold.
Sorry for the long post but this is driving me insane and any help/input would be greatly appreciated. Much thanks in advance.
Old Mar 24, 2016 | 03:33 PM
alloro's Avatar
alloro
We only go up to 2006 in this forum, here is the forum you want: 2007 - 2014 Expedition & Navigator - Ford Truck Enthusiasts Forums
Old Mar 24, 2016 | 03:40 PM
Rodjak's Avatar
Rodjak
Thanks.. I am new to this forum
jenfrank
Mar 6, 2017 10:05 AM
Rodjak
Mar 24, 2016 06:28 PM
wondrn
Jul 22, 2014 06:40 AM
jamull2852
Modular V8 (4.6L, 5.4L)
Mar 28, 2013 09:43 AM
kris.carter
Sep 6, 2012 05:41 AM
