Nitrous Oxide for EFI 7.5
I bet it could take a 200 wet shot without much complaint. We're pushing 12 PSI of boost through one.
However, I wouldn't run nitrous on a 460 with stock engine management without a window switch. The rev limiter is around 4500 RPM or so, and it's a full fuel cut, so you will go very lean if you crash into the limiter while spraying.
outinit
07-11-2010 09:39 PM
71F250CS
10-08-2002 10:06 AM
