High Output Heater
Old Dec 7, 2003 | 10:04 PM
hillbillyk's Avatar
hillbillyk
I am looking for a high output heater for my 78, how do you tell them apart from the standard heater?
Old Dec 8, 2003 | 07:16 PM
patsplace's Avatar
patsplace
I just bought a High Output core for my '78 F250 4WD and I was told that there were three cores avaiable. Standard, Air Conditioned and High Output.
Pat
Old Dec 8, 2003 | 08:08 PM
Chas1234's Avatar
Chas1234
FYI 1978-1979 broncos also have the high output heater , so '78bigbronco you already have one - ( at least my old '78 bronco had the HO)
Old Dec 8, 2003 | 09:29 PM
pdqford's Avatar
pdqford
My '79 non-A/C truck has the HO heater option. There is a small tag just above the heater controls that reads "High Output"
Old Dec 8, 2003 | 09:43 PM
patsplace's Avatar
patsplace
Same little tag with mine too. I was glad that the Lariat came with it 'cause it's a real flame thrower of a heater. You do not run that one on high unless it's COLD, COLD outside.
Pat
Old Dec 9, 2003 | 01:10 AM
Coonhunter2x1978'S's Avatar
Coonhunter2x1978'S
does anyone know if the 78 ranger explorer A/C came with a HO heater?
Old Dec 9, 2003 | 10:04 AM
Crumm's Avatar
Crumm
My 75' standard cab says "high output" on the controls but my 76' crewcab doesn't. Are you all sure that all crewcabs came with the high output system? I am thinking about parting out the crewcab so I may have the high output system to sell but I need to know what I have. I need a few of the parts off of the crewcab for my 75' but it is almost to good to dismantle. Decisions, decisions.......
Old Dec 9, 2003 | 03:58 PM
Colossus's Avatar
Colossus
Crumm,
Since the HO heater is standard in SC and CC, it wont be labeled on the dash. My dads 78 SC doesnt have it marked, my 79 RC has it marked because its an option in the RC trucks.
Old Dec 10, 2003 | 09:18 AM
73Custom's Avatar
73Custom
Re: High Output Heater
COONHUNTER2X1978'S, you must have overlooked this post:
Originally posted by FORDBOYpete
HO Heaters are standard fare w/ all A/C systems, & in all Super & Crew Cab trucks F-150 through F350.
Marty
Old Dec 14, 2003 | 09:52 PM
patsplace's Avatar
patsplace
Canadian Tire offered me a standard and a High Output, AC or Not was the choice.
Pat
Old Dec 14, 2003 | 10:37 PM
jevans's Avatar
jevans
My 76 F250 has an electric element in the duct under the dash that gets red hot when you turn on the heat.
Whats up with that?
Was it an option or standard?
Old Dec 15, 2003 | 12:09 AM
patsplace's Avatar
patsplace
You got me on that one. Sounds like somethings wrong in your system. Far as I know, they all work off water heat. Have never heard of a separate element that glows. Sounds like it could drain a battery in a heartbeat.
Pat
Old Dec 15, 2003 | 01:03 AM
  #28
jevans's Avatar
jevans
lol...no it looks factory and it comes on when you turn on the heat. Its small, the size of a roll of quarters. And the fan wont come on unless its pluged in.
I was warming up the truck one morning and smoke started filling up the cab real quick. I thought I was having an electrical fire. It turned out to be leaves in the bottom heating duct that the element was burning.
Old Dec 15, 2003 | 01:25 AM
  #29
patsplace's Avatar
patsplace
Kewl!! I was on Vancouver Island the other day and I was chatting with a guy about his Mercedes 125,000.00 sedan and one of the points that he was kinda boasting aboujt was a similar heating element for the windshield that sounded like it worked much the same.
Neat device. Wonder what it's called, when they put them in and all of that.
Pat
Old Dec 15, 2003 | 07:21 AM
  #30
MitchPeters's Avatar
MitchPeters
I put a HO heater box out of a '76 into my '79F250. Neither had A/C and I used the standars '79 controls. After taking everything out I noticed the only difference in the two boxes was that the standard '79 box had a plastic spacer in it to hold the bottom of the heater core. After putting in the '76 box I also discovered that the rubber on the flaps to go from heat to defrost were leaking, basically rotten, so I tore it out and took out the spacer and put in the bigger heater core into the standard '79 box and it worked great. Go buy the bigger core and put it in.
