I'm planning on installing a rebuilt engine in the near future. Are there any special tools, beside a clutch alignment tool, I will need to get a hold of?
Is it easier to pull the engine by itself, or should I pull the engine/transmission as a unit? Are there any tricks to any of the process that you guys can share? I've never done it before and would like to know the Do's and Don'ts.
i did my 302 twice. you need the spring clip tool ( fuel lines) i perfer to pull with out the trans. it is just easier that way as far as i am concerened. advice find someone that has some expericance with pulling engines. and take your time. good luck ( slave2damud(No Email Addresses In Posts!)) my email contact me if you need any more info
