fuel gauge
Old Aug 12, 2003 | 09:34 AM
PRyan1983's Avatar
PRyan1983
fuel gauge
On my 72 f100 the fuel gauge shows 3/4 full when I fill up the tank. The gauge works fine between empty and 3/4 full. Why doesn't it go all the way to full when the tank is filled? Any info will be appreciated. Thanks.
Old Aug 12, 2003 | 10:28 AM
BB's Avatar
BB
fuel gauge
Hey you're a day late!
http://www.ford-truck.com/forums/sho...hreadid=141982
Old Aug 13, 2003 | 09:57 AM
georgiaford67's Avatar
georgiaford67
fuel gauge
You can ohm out the fuel guage also. With the guage at full you should have around 14 ohms. With it empty you should have around 80 ohms.
Old Aug 13, 2003 | 02:52 PM
PRyan1983's Avatar
PRyan1983
fuel gauge
How do I ohm the gauge? I don't understand what that means.
Old Aug 13, 2003 | 03:35 PM
georgiaford67
fuel gauge
You will need a multimeter( electrical test). turn the selector dial to ohms ( measuring resistance in a circuit). The ohm symbol looks
like an upside down horseshoe. Unplug the orange wire at the sending unit and put one meter lead on the sending unit terminal and the other black meter lead to ground. If your guage is full it should read around 14 - 16 ohms.
It is best to take the sending unit out and move the float all the way up and all the way down checking the variable resistance.
around 14 all the way up and around 80 all the way down. resistance will vary from unit to unit. One other thing to mention is if your sending unit is showing a change in ohms, then it's most likely good, you may have a problem with the float going all the way to the maximum when full( hole in float) or something physically stopping it.
good luck
rich
broncoholic
May 11, 2017 09:19 PM
Ronnief150man
Mar 20, 2017 11:54 AM
nathank
Nov 14, 2016 11:18 AM
texasblue55
Jan 28, 2016 10:51 AM
Ajax 1
Sep 4, 2015 01:07 PM
