Prepping 2006 DRW for towing across country
on
My experience was different, at 96,852, the original plugs were way past due and #2 had ejected. The center points were almost gone leaving the gap twice as wide as it should be. Every other picture I have seen of original plugs anywhere near that mileage show the same thing. The gap gets way too wide well before 100K miles. Someone posted their plugs changed @ 120,somethingK and the ground straps had chunks burned off them. But it still "started and drove". No thanks, not in my engine.
This is the first I remember seeing anyone recommending NOT changing the plugs early, on any modular. I certainly wouldn't "wait until they misfire & change them on the road".
Best of luck OP, whatever you decide. I hope you err on the side of caution instead of letting your maintenance go until something breaks.
I ordered this one. Has worked flawlessly with my Android phone for over 3.5 years.
I have a magnetic mount for my phone on my dashboard, and I keep Torque app up and running whenever I'm towing/hauling.
JD Dixon
1999 to 2016 Super Duty
05-20-2010 08:13 AM
