1988 460 engine issues
Old Mar 18, 2016 | 01:11 PM
1988fordf350's Avatar
1988fordf350
I have a 1988 ford f350, when I start it up it idles very rough and when you stop at a red light it acts like its going to die. When driving it normal it runs great but once using it for towing its seems like your pulling with a 6 cylinder not a big block 460. Not sure if I got a vacuum issue or the EFI. The truck only has 48,000 miles, 2wd single cab dually 5speed. Thanks for any help.
Old Mar 18, 2016 | 06:02 PM
rla2005's Avatar
rla2005
How old are the plugs, wires, cap & rotor?
Is the Check Engine Light on?
Regardless if it is or not, run the Key On Engine Off (KOEO) tests and Stored Code display. List the two digit codes by number and when they were displayed.
Old Aug 20, 2016 | 11:11 AM
1988fordf350
it doesnt have a checkengine light on ill check it out thanks
Old Aug 20, 2016 | 12:56 PM
KYSlowhand's Avatar
KYSlowhand
Details like how long has this been a problem or has it sat a long time so it could be bad fuel?
Old Aug 20, 2016 | 01:34 PM
justcruzin125's Avatar
justcruzin125
The 460 isnt exactly fast. Its actually pretty slow towing especially uphill. Depends how heavy the trailer your towing. My guess is a tuneup is in order if nothing else
1988fordf350
Mar 13, 2016 04:01 PM
1979F-150Man
Jul 6, 2010 06:05 PM
jugheadz
1997 - 2003 F150
16
Feb 7, 2005 06:42 PM
briansrapier
Apr 26, 2004 12:16 PM
briansrapier
West Virginia Chapter
Apr 22, 2004 06:27 PM
