Making a List of Upgrades for Increased Towing Capacity
1991 Ford F150
302/5.0 engine
2WD/E4OD A/T
As time passes, my finances will improve and along with other upgrades, I want to reasonably increase my payload/towing capabilities from what I have now. Currently, I have the stock Class IV bumper rated at 8,000 lbs. From all you towing experts, I'd like to know any/all upgrades that might increase my towing capacity. Thanks for any help.
302/5.0 engine
2WD/E4OD A/T
on
Yes there are finite limits on what each series of truck can tow but within that series(F150 in this case) there is a range of towing capacities based on the engine, trans, and axle ratio. The auto transmissions get higher ratings compared to manuals and we're gonna assume for now you're not gonna change the engine, but given that there is a significant difference between the official tow ratings and the real world towing performance as you progress through the available axle ratios from 3.08 to 4.10. This you can change and get a little or a lot higher towing capacity depending what ratio you are starting out with. Then adding sway bars, air bags or overload springs, and stiffer tires will all help improve control with the load.
I dont think axle ratio has anything to do with towing capacity, yes different ratios will make put the engine in a different RPM band which can be better for towing but there is no capacity change between gear ratios that I know of. Actually the numerically higher you go with gear ratio the weaker the ring gear becomes because it gets smaller in physical size.
1991 Ford F150
302/5.0 engine
2WD/E4OD A/T
302/5.0 engine
2WD/E4OD A/T
As suggested several times, the capacity can't be changed. Ride quality and handling while towing maybe.
You didn't say what you have in mind in terms of the weight you want to tow.
Steve
on
Well that is where you would be wrong.
A 5.0/auto F150 of this vintage has the following tow ratings based on the axle ratio. This info is pulled right from the owners manual under the trailer towing section. Trailer frontal area not to exceed 60sq ft. For the OP GCWR is the ready to travel weight of truck and trailer and all passengers combined and it is the number than cannot be exceeded, and trailer weight has a range because the loaded truck can range in weight and it also depends what body style and options the truck has, for example a reg cab 2wd can be as light as about 4000lbs but an ext cab 4x4 can be over 5k.
Gear ratio GCWR Trailer Weight
3.08 9000lbs 2000-5000lbs
3.55 11.5klbs 3500-7700lbs
4.10 12.5klbs 3500-8000lbs
Our trucks already run out of cargo capacity long before they run out of towing ability.
Towing Capacity For 1990 F350 7.3 Diesel - Diesel Forum - TheDieselStop.com
O.P.'s initial post stated "I want to reasonably increase my payload/towing capabilities". Being able to pull more is not the same thing as being able to carry a heavier load, though they are related.
Then his post went on to say " I'd like to know any/all upgrades that might increase my towing capacity."
We may be assuming too much. It might be helpful to get a better handle on what he intends to do with his truck. Just my thought.
Steve
Steve
