dana 60 question
Old Mar 18, 2016 | 03:46 AM
kupiec20's Avatar
kupiec20
dana 60 question
so ive decided to a dana 60 swap
since I put new pads and rotors on my dana44 can I swap those over to my dana 60?
Old Mar 18, 2016 | 07:16 AM
Az_Green_Machine's Avatar
Az_Green_Machine
I think you mean you put pads and rotors on your D50. I can't recall anyone mentioning doing a caliper swap when changing the axle so I would assume the pads are fine, as for the rotors I would look up part numbers for the ones you have now and the ones for the axle out of the donor vehicle and compare them. Im sorry I don't have an actual answer just giving you a way you could check for yourself.
Old Mar 18, 2016 | 12:06 PM
ReBilld's Avatar
ReBilld
You can swap the rotors and use your calipers that are on the truck as long as the D60 you get is a late '95 and up. Early '95 and back they used different steering knuckles, calipers, and 12" rotors. You have the bolt on calipers and 13" rotors on the '96.
Old Mar 18, 2016 | 01:05 PM
kupiec20's Avatar
kupiec20
The truck i took it out of is a 95'
By looking at the axle how do i know which one i have?
Old Mar 18, 2016 | 04:13 PM
farmert's Avatar
farmert
Later D60 use bolts to hold the caliper on. Early ones have Tapered pins with rubber in the center of the pins to hold the caliper on.
1995F150XLT4x4
Nov 20, 2015 10:04 PM
Andy Sullivan
Jan 16, 2012 06:50 PM
Brown Falcon
Aug 9, 2011 04:41 PM
SPL Tech
Mar 30, 2007 01:41 AM
barebackjake
Nov 22, 2004 09:07 PM
