73 f250 died when hot
Old Mar 17, 2016 | 05:34 PM
mountain dewd's Avatar
mountain dewd
Gents, the water weather seems to have brought about a new symptom. I was tuning my truck up and it got pretty warm when idling (200º) took it for a drive, drove really well, then it started cutting out at higher throttle. Almost smoothed out. Didn't really miss, just lost power and cut in and out. Pulled over and it quit on me. Stumbled and flat died. Wouldn't restart. Fiddled around, got it to pop over. A little while later, it started and I foolishly tried to turn around. Died, sideways in the road. Folks just invented new ways of going around instead of bothering to help.... Got it to start again, and no playing around, just hit it in reverse. Got a ways, and was able to turn around. Truck then idled fine and drive great the rest of the way home. When I pumped the throttle when it was very hot, the accelerator pump sprayed a good stream of fuel. Does this sound electrical to you, or fuel related? Thanks a ton.
Old Mar 17, 2016 | 05:42 PM
Steven@nd's Avatar
Steven@nd
I have had coils go out when hot and provide spark again once cooled... after your ballast resistor providing high voltage you may have fried the coil?
When it quits check for spark...
Old Mar 17, 2016 | 05:45 PM
mountain dewd
That is a good thought, but I just bought a new coil, and have not had BR issues since.
If I can get it to quit again (hopefully not), I will give it a shot for spark. Just by the way it was cranking, it was getting zero ignition, whether that be fuel or spark. Started pretty weakly when it did, but quickly smoothed out and ran great.
Old Mar 17, 2016 | 06:39 PM
Steven@nd's Avatar
Steven@nd
Also had a farm truck that would die when hot... turned out a rubber fuel hose going to the pump collapsed when hot. Check fuel hoses to be sure they are firm and not kinked.
Old Mar 17, 2016 | 06:59 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Vapor lock? Clip a wooden old style cloth pin on the fuel line up by the carb...it works for some reason.
In line fuel filter, carb filter? New coil could be going bad?
Old Mar 17, 2016 | 07:27 PM
mountain dewd
Great suggestions guys, I will give them all a try.
KubotaOrange76
33
Nov 4, 2021 12:34 PM
wilfred sidney Romer
Nov 29, 2016 01:36 PM
Captbs32
1978 - 1996 Big Bronco
Jun 24, 2012 10:35 PM
jones189
Aug 6, 2009 09:16 PM
JOSEPHU
Apr 8, 2008 12:15 AM
