New to me 01 Excursion v10 GEM issues.
I've recently acquired an 01 Excursion (cheap) with a couple of issues that I believe are related to a previously replaced GEM that may not have been properly programmed. Any help relating these issues to the GEM (or not) would be much appreciated. I contacted my "local" Ford dealer 30 miles from here and they quoted $119 for an hour of shop time to lookup my VIN and reprogram the GEM with the original options.
What it is:
2001 Limited Excursion
4x4
V10
What is not working:
I've owned 2 first gen Expeditions in the last 3 years so I'm familiar with several of the quirks of Ford trucks already.
What it is:
4x4
V10
That would be my guess, as far as the door chime it could be broken/removed in some other way. I'm trying to figure out what is related to the GEM and what has no relation to it. I'm not even sure if the AC is tied to the GEM or not.
It could be faulty, no way of telling at the moment. I'm hoping the programming is just wrong and it can be corrected by the dealer.
I was able to use Forscan to look at the programming on the GEM module, the 4x4 was set to manual engage. Resetting it to electronic restored the function of the 4x4 selector switch on the dash. Also a DTC was flagged for the over head console / trip info.
Does anyone know where to get an as-built data sheet so I can restore the rest of the missing functions? I'm going to head over to the local dealer this week to see what they say/can do.
See if the FordEtis link in this post will get you the as built data you need.
https://www.ford-trucks.com/forums/1...l#post13471414
Good luck!
Good luck!
Success!
I was able to have a Ford tech look up the AS-BUILT codes from my VIN. I was able to use Forscan and a generic WIFI OBD2 reader ($20) to restore my GEM features to factory spec thus fixing:
Dome/exit lights are acting in a different manner now instead of just shutting off when I close the door.
I need to check the cruise control, it might be malfunctioning due to a brake light DTC code I found. AC is not engaging at all, need to troubleshoot.
- Rear Wiper
- Defrost
- 4x4
