Anybody with pictures of 94.5-95 hpop and 96-03 hpop?
I don't remember now that I just installed my HPOP after taking it off, but looking at those pictures, I think I may have a 96+ HPOP on my 95 engine.
What are the complications of not having the check valve on the HPOP if my 95 needs it? Also, what would be the best course of action to fix this issue if my 95 does in fact need it and I don't have it? I'm hoping it's not a new pump...
Edit: I just pulled my HPOP off to make sure and it does DOES NOT have the anti drain-back valve.... therefore I think it is not for a 95. Is there anyway this setup could work for a 95? Or am I going to have to buy a 95 specific pump?
Edit 2: I just check the other side of the timing cover where the pump would mount and it doesn't have a check valve thing their either, just a small hole..... I really hope I don't have to get a new pump..
Edit 3: Well..... I got ansy and just bit the bullet. Ordered a manufactured cardone HPOP from Rockatuo for 515 after shipping..... maybe I can sell my old one?
Hmm.. well I know the pump I got was working for the motor, but I noticed the HPOP reservoir was empty when I went to pull that apart and reseal it.
I don't think there is any way for the reservoir to stay full without the proper pump for my engine unless I change out the timing cover to have that check valve instead. The engine was having a really tough time starting before and I think it's because the HPOP reservoir was empty on oil each time I went to start it! That, and the oil cooler check valve thing was missing as well....
I looked at that, but from what I understood on the website is that they rebuilt my old pump to make it a T500. I also read that I must have the housing from a 94.5-95 to get the valve, so I don't think they could have made it that one...
Hmm I had the cover and oil pan off and didn't remember seeing where it might be on my truck... then again I was looking for it. I do know that the timing cover didn't have a valve which I read the valve was on some of the timing covers... I could always return the pump I bought if my old one was correct, but I think I do need that valve on the pump I ordered. I know my HPOP reservoir was empty when I tried draining it.
Hmm maybe there is a part number on the pump that you could check with Ford? I don't really know though.... you know a lot more than me!
The anti drain back valve is in the block on the 96+ trucks. If your 95 is a late build it may have it there. Hard to say though.
Ok one of them is for a 94.5-95 the other is a 96-03 but dont know if its a 15° or 17° pump.
