Let's Play . . . "NAME THIS THING!"
Old Mar 13, 2016 | 08:51 PM
chukar's Avatar
chukar
I've been around trucks, many kinds, and 4x4's since I was 15, and that was 54 years ago, but I have absolutely no idea what this is; or what it does. I'm anxious to have my curiosity quenched. Thanks a lot. Vic
Old Mar 13, 2016 | 09:01 PM
skidoodave's Avatar
skidoodave
Old brake controller for trailer brakes?
Old Mar 13, 2016 | 09:06 PM
co425's Avatar
co425
Bingo! Kelsey Hayes brake controller.
Old Mar 13, 2016 | 09:17 PM
fordguy2100's Avatar
fordguy2100
Y'all beat me to it, I have that exact one in my 74
Old Mar 13, 2016 | 09:22 PM
monkey-1's Avatar
monkey-1
I haven't seen one like that in YEARS!
Old Mar 13, 2016 | 09:34 PM
chukar's Avatar
chukar
Obvious actually, now that it has been named. Should have thought about it myself. Wonder if it still works. Not important though now that I know the truck won't explode when it's yanked out. Thanks guys.
Old Mar 13, 2016 | 09:41 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
So old school that it is tapped into the brake system. All you see now days is an electric one. Cap off the T when removed.
Old Mar 13, 2016 | 09:48 PM
chukar's Avatar
chukar
I have zero idea what you mean about "the T," but it make me think I should be cautious when removing it. :-) So did this control the truck's brakes or the trailer's brakes? Or both somehow???
Old Mar 13, 2016 | 09:58 PM
77&79F250's Avatar
77&79F250
Look over your controller very well, look for a solid brake line coming from it, and going thru the fire wall and T'ing into you master cylinder.
I think is use to work by getting/sensing brake line pressure from the m/s and then converting that to an electric signal and applying it thru the trailer wiring to the electric trailer brakes.
Old Mar 13, 2016 | 10:06 PM
chukar's Avatar
chukar
Well now, that is old school. Thanks a lot for the directions. That thing just looks obnoxious and I want it out of there for that reason alone.
Old Mar 14, 2016 | 06:33 AM
lpdcjr's Avatar
lpdcjr
They do work well tho. Still preferred by some guys because they operate off of pedal pressure vs electronic signal. They dont work so well on abs systems, one reason they arent available any longer
Old Mar 14, 2016 | 07:41 AM
ktm4012's Avatar
ktm4012
I still have one on my 79
Old Mar 14, 2016 | 10:11 AM
NDF250's Avatar
NDF250
I also have one in my 78. I'm in the process of putting a new master cylinder and booster on. Is there any special instructions when it comes to bleeding the line to the brake controller?
Old Mar 14, 2016 | 11:19 AM
chukar's Avatar
chukar
In investigating this controller I may have been hasty to conclude it should be 86'd. Can anyone tell me if any component has to added to the towed vehicle for this system to work as designed?
Or maybe go to the trailer forum where this question probably belongs? :-)
Old Mar 14, 2016 | 02:21 PM
co425's Avatar
co425
As long as it works, and is wired correctly you shouldn't have too. You may need to swap out your trailer conncetor plug to a newer standard.
Did the manual in that link I posted come up?
