Offroad & 4x4
Mud Drags
Old Aug 11, 2003 | 08:55 PM
grappledad's Avatar
grappledad
Mud Drags
I was thinking about entering my truck into a mud drag competition and I was wondering if a could make my stock Ranger lighter but keep the V6 and still run in the stock class. Thank you for the help
Old Aug 11, 2003 | 10:14 PM
pipefitterpro's Avatar
pipefitterpro
Mud Drags
Wierd as it may seem, in Mud drags lighter isnt always better. Getting the vehicle to "hook" and accelerate is the key to having a good quick run. I've seen many times where a truck was stripped down with lots of Hp but couldnt beat some of the less worthy entrants. Mud drags arent like asphalt drags, a drag car can use weight transfer to its advantage in getting the car to grip the track and produce low 60 ft times. I would be more concerned about tire and gear choice for the stock class. In any case, get a copy of the rules from the group putting on the drag and see what they will allow in the stock class. There are usually differences in the rules depending on where you plan to race. Most races have a minimum wieght for each class so as long as you meet it (including Driver) you should be ok. Good luck!!
Andy
'77 Bronco, 1957 Chevy (2 door car) Mud dragger 900 hp, 180' in 2.73 sec
Old Aug 12, 2003 | 01:13 PM
proeliator's Avatar
proeliator
Mud Drags
I've never seen points given for simply lightening your vehicle. You should still be able to run in the stock class.
Old Aug 12, 2003 | 11:10 PM
red_rocket's Avatar
red_rocket
Mud Drags
the biggest thing about mud drags, is tall skinny tires.
the first bog I went to, with 34x9.50 swampers on my stock F-150, I took second place(was beat out by .1 second)
Now with wider, mt's, I cant even place.
There are only two tires that will EVER place in stock class, 34x9.50 swampers, and N78(33") buckshots.
for the next class up, if you dont have 38X11 boggers, forget about the trophies.
also, the biggest thing to drving, is your line, and the holeshot.
do you have a stick, or a auto?
Old Aug 12, 2003 | 11:44 PM
nbaff's Avatar
nbaff
Mud Drags
You might just want to wait on the performace stuff. Just go get some Mud tires and enter. See what ya do. Then adjust accordingly. No sense in spending money that you might not have to. You can't expect to win the first time out.
Old Aug 16, 2003 | 05:06 PM
3broncocrazy's Avatar
3broncocrazy
Mud Drags
What about the consistancy class - you just have to make the same time
Old Aug 16, 2003 | 06:08 PM
pipefitterpro
Mud Drags
Hmm... I have never heard of a consistancy class for Mud drags. I know about running bracket drags on asphalt where you run your "dial in" and try to come as close as possible to your number without going faster than your dial in. Where are you running these kind of drags? Sounds like fun.
Andy
Old Aug 17, 2003 | 08:59 AM
3broncocrazy
Mud Drags
South Georgia
It's a blast, you can side by side with anything - just don't beat yourself
Old Aug 17, 2003 | 07:11 PM
pipefitterpro
Mud Drags
Cool, sounds like a blast. Wish it wasnt so far from Michigan. Take care,
Andy
Old Aug 17, 2003 | 07:16 PM
proeliator's Avatar
proeliator
Mud Drags
I've never seen a consistancy class in mud drags out here either. Doesn't seem like a race unless your racing somebody else...
Old Aug 17, 2003 | 07:20 PM
3broncocrazy
Mud Drags
It's side by side, so you still get to pass someone stuck every now and again
Jordan532
Jan 31, 2012 07:07 AM
ExtrmZ
North Dakota Chapter
Dec 30, 2011 04:38 PM
FordTrucksKickGM
Nebraska Chapter
Aug 20, 2007 02:34 PM
FORD_LOVER
Nebraska Chapter
Jul 15, 2006 11:21 AM
fordsrgrt
Iowa Chapter
Jun 4, 2006 11:41 PM
