2003 F150 4X4 XL Ex.cab help please
Old 03-10-2016, 10:18 PM
Ardvaark's Avatar
Ardvaark
Ardvaark is offline
Thumbs up 2003 F150 4X4 XL Ex.cab help please
I hope there is an easy solution to this besides replacing the instrument cluster.
Problem is my truck just failed smog inspection(California). You'll never guess why in a million years I promise, totally floored me. Here it is, I failed because the service engine light is not coming on when you turn the key to the ON position. This has got to be a new one. Anyway so after a little bit of panic I thought that it could be something as simple as a bulb in the instrument cluster, well it is kind of, SMD LED. Can you believe it? Does anyone have any experience with this? I've also noticed that there are 2 or 3 other LED's on that side of the cluster that are not lighting up either. Am I hosed? Throw the truck away? I would love to do a board level repair on this because I'm pretty good with a soldering iron and electronics in general. These LED's are unlike anything I have ever seen before. What do you guys think?
Thanks!!!!
Old 03-11-2016, 01:30 AM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
If your sure there are other LEDs not lighting, a board or connector issue is likely.
Work on it to at least give yourself a possibility of repair.
You know better than to ask for an easy repair because there is only one and that's to do it or replace the display.
You don't give up a truck for a dash display issue.
Good luck.
Old 03-11-2016, 01:34 AM
Ardvaark's Avatar
Ardvaark
Ardvaark is offline
Thank you for that, I will check the connectors. I would never give up this truck, I would die first. When this happened to my truck it affected me deeply. I want to fix her!
Old 03-11-2016, 02:28 PM
Ardvaark's Avatar
Ardvaark
Ardvaark is offline
Unhappy
Well I resoldered a bunch of cold solder joints and went over the entire board with my usb microscope and can't find any problems. Does anyone have a schematic for this board? Parts and such, I have a feeling it could be a transistor..
Ardvaark
1997 - 2003 F150
03-22-2016 10:58 AM
crzrlou
1997 - 2003 F150
01-22-2013 01:36 AM
vesecky
1997 - 2003 F150
08-07-2012 11:58 AM
JB Dingus
09-21-2011 12:19 PM
ijuslikefords
1999 to 2016 Super Duty
05-24-2007 04:19 PM
Quick Reply: 2003 F150 4X4 XL Ex.cab help please
