Security...gauges...key code. Replacement question
Old Mar 10, 2016 | 09:11 AM
HiZ's Avatar
HiZ
The key. ...
Okay my truck has a dead dash. Tach did not work when i purchased it, now gauges with fail intermittently at times and that's annoying.
Check and test said the gauges are the issue not signal.
If i remember correctly the security is in the dash and the dash reads the key. I have more than 1 of these and was going to swap parts.
If i pull the cluster to put in other truck is it proper to:
Take the key with the new to install cluster from donor truck and use that key for the code, program to a new blank, cut that blank to fit the tumblers on the recipient truck?
Summary: the key would be cloned to a blank from donor truck to follow gauges and cut for the ignition and doors on new installed truck
That was my thinking but sometimes I'm not spot on
Any help is appreciated
Old Mar 10, 2016 | 11:03 AM
projectSHO89's Avatar
projectSHO89
Excursions never had the version of the PATS system that incorporated PATS into the instrument cluster, they all used an external PATS module that communicated directly with the PCM.
Old Mar 10, 2016 | 01:16 PM
HiZ's Avatar
HiZ
So I can swap gauges and the thing will not Implode?
Old Mar 10, 2016 | 01:17 PM
HiZ's Avatar
HiZ
What's the part that fails when the wire for OD on/off button on shifter rubs and shorts out killing fuse and then killing all power to the gauges and not allowing for restart?
That's the one! see
Old Mar 10, 2016 | 01:26 PM
projectSHO89
Originally Posted by HiZ
What's the spec that fails when the wire for OD off rubs and shorts out killing fuse 11 and then dumping all power to the gauges and not allowing for restart w/o signal ref. to gauges?
That's the one! see
Uh, that doesn't make any sense....
Old Mar 10, 2016 | 01:35 PM
HiZ's Avatar
HiZ
Is it post 03 that has a PATS System?
Or as built data to put into the vehicle specific details: PMC, Gear Ratio, Etc.
HiZ's Avatar
HiZ
Or digital Dash system?
Old Mar 10, 2016 | 01:41 PM
HiZ's Avatar
HiZ
The wire that shorts from rubbing on the column:
The wire to the OD off/on tip of the shifter
That shorts and kills power to the cluster and PATS system (as I was told)
So you loose power to radio/gauge/windows and once you shut it down it will not restart w/o change of fuse or power to system
christofalex
Dec 29, 2016 12:28 PM
pancake
1997 - 2003 F150
Aug 4, 2016 12:28 AM
SideWinder4.9l
May 2, 2012 10:46 AM
4realestate
Mar 28, 2012 08:54 PM
Stevan
Electrical Systems/Wiring
Jan 15, 2010 08:01 AM
