1988 Ford F-250 , 460cu. As I was driving on the x-way my truck acted like it was out of gas. Put gas in and no go. I had it towed home and charged the battery. It will start if I keep my foot on the pedal but runs VERY badly. Had the fuel pump checked and it is fine. Does the same on both tanks. Could it be the Duel Fuel Reservoir plugged up? This is my only vehicle. Just had a new distributor put in and a turn up and it was fine before this. HELP!!!
Fords have an emergency fuel shutoff switch on the passenger side under the trim by where your right foot would be. It has a red button on the top and sometimes it can get bumped and will shut of the gas. Just an idea.
Does "Had the fuel pump checked and it is fine" mean that you tested the fuel pressure at the rail?
"It will start if I keep my foot on the pedal but runs VERY badly"
First impression sounds like its running just a tad too rich.
Pull the vac line off the fuel pressure regulator, check for evidence of fuel in the vac line/start it and see if fuel leaks from it's vac line port.
If you haven't checked the fuel pressure, it'd be a good place to start unless find obvious problems right off the bat with the FPR.
Running the KOEO self test and retrieving any continuous memory codes would be a good idea along with fuel pressure/system check.
Yes, he fuel pump was checked at the rail. 40 lbs. It ran great until this. It's been running the code for the EGR sensor but it been running that for a while.
Fuel pressure sufficient for idle, who knows at this point at speed and under load but should idle yea.
Check for any new codes that might lead to cause of the problem?
When running what does the exhaust look like, looks normal very little to no smoke? black or heavy black smoke?
Might want to pull a couple plugs, see what they look like.
Old EGR code, EGR valve stuck in open position?
Wouldn't have stalled it out while holding part throttle and at cruise speed on the highway but might be causing grief now. It opened then stuck there, you let off the throttle for whatever reason slowing down little bit, it failed to close so unable to recover stalling it out.
It will only run with the pedal all the way down and sound AWFUL. I don't have a code reader and the truck isn't going anywhere.
Holding it to the floor is doing two things, shutting off the injectors and giving it massive amounts of air.
One or the other or both allowing it to run.
Put the fuel pressure gauge on it, cycle the key from off to run a couple of times to let it build fuel pressure, if one time gets it 35 to 45psi that's fine but get it to that range.
Then turn off the key while watching the fuel pressure gauge, it should hold within 5psi of spec for 1 minute, however a good working system will hold and for quite a while before dropping much if at all. Point is it shouldn't drop right away and right to zero.
:could it be the crankshaft position sensor. It is not throwing a code for it.
There is no Crankshaft Position Sensor per se. The PIP sensor in the distributor is the trigger for spark and fuel injector firing. There is a CM code for erratic PIP signal.
