Sponsored by: Real Truck
V10 running rough
Old Mar 7, 2016 | 08:54 AM
huskyfan68's Avatar
huskyfan68
V10 running rough
2001 V10- F250.. Runs rough- had the computer put on it and was coming up with P0174 codes (I think that is right)- In any case I replaced the Mass air flow sensor- checked for any vacuum leaks visually- I did not see anything obvious.... still runs like crap.... smells like gas when idling.... anything else I can check??? The check engine light went off finally (probably due to the MAF)- but it's driving me nuts- Any hoses I have not located I need to check?
Old Mar 7, 2016 | 10:53 AM
r2millers's Avatar
r2millers
Replace the infamously known pcv elbow, back of the pass side valve cover. Usually the culprit.
Old Mar 7, 2016 | 11:02 AM
01EXC's Avatar
01EXC
also you can use starting fluid to find a vacuum leak. just spray it around the intake manifold/ any vacuum hoses, the brake booster, etc. if you hear your idle change tone at any time, that's where your leak is.
Old Mar 7, 2016 | 05:51 PM
Bugzilla46310's Avatar
Bugzilla46310
Whenever mine ran rough (2 times) it was a spark plug coil gone bad.
Old Mar 7, 2016 | 08:57 PM
huskyfan68's Avatar
huskyfan68
thanks for the responses- I think if it was coil or plug I would not smell gas no?
I will try the pcv hose and also the started fluid thing- I also was going to try the "smoke" test- Does anyone know where I attach the hose with the smoke coming out? I know it's supposed to be a vacuum inlet somewhere but I'm not sure where to attach it
Old Mar 7, 2016 | 09:22 PM
darkjedi351's Avatar
darkjedi351
carb cleaner works great for finding vacuum leaks. sounds like it's your pcv elbow
Old Mar 7, 2016 | 09:33 PM
Tom's Avatar
Tom
An ignition problem can't cause a lean code. The problem is most likely a vacuum leak, and of course the PCV elbow is the primary culprit.
Old Mar 7, 2016 | 10:52 PM
twigsV10's Avatar
twigsV10
Check the big rubber grommet on the bottom of air filter assembly where the wires for the MAF sensor come out.
Old Mar 10, 2016 | 11:35 AM
huskyfan68's Avatar
huskyfan68
thanks all- ugh- still happening- Replaced the MAF sensor- replaced the PCV- checked every vacuum hose I could see- Used the carb cleaner test-. I also cleaned the throttle body as much as I could. Still cannot find why she is running so sluggish- The check engine light turned off after the MAF sensor was replaced (I did disconnect battery)- then it went back on..... not sure what esle I can check
Old Mar 10, 2016 | 09:24 PM
z31freakify's Avatar
z31freakify
Was the pcm programed? Check the throttle body, take it off and clean it sometimes they get stuck with crud and give false readings.
Old Mar 11, 2016 | 10:01 PM
twigsV10's Avatar
twigsV10
After thinking about this some more I'm guessing you have multiple plugs miss firing on the driver side (p0174 is for bank 2 running if I remember correctly)? If a cylinder isn't firing it's just an air pump into the exhaust, and if you have a functioning catalytic converter the lack of fuel smell from the exhaust is because it's burning in the cat.
stowbilly96
Dec 21, 2024 11:38 PM
jfetter85
Modular V10 (6.8l)
Aug 10, 2019 08:27 PM
2001 Excursion Owner
Mar 11, 2019 11:06 AM
tturbonegro
Modular V10 (6.8l)
Mar 24, 2014 12:21 AM
sontours
Escape & Escape Hybrid
Jan 25, 2012 01:58 PM
