The Super Duty I purchased came already equipped with a B&W turnover gooseneck ball. In previous instances I've never been a fan of the turnover ball. However, it came with the pickup and I will keep it. I do pull gooseneck trailers and it is something I will not part with.
The issue is mounting the rails for the 5th wheel. This is also a not negotiable. The rails which are B&W have an offset of 32 1/2 inches from the back rail to back edge of the box and the Reese rails are 30 3/16 from the rail to the box.
It looks like the B&W with the 32 1/2 will be in the way of the brackets on the gooseneck ball. I am concerned if I follow the Reese instructions that I'd be behind the axle or not far enough ahead to push the weight forward.
The camper I pull is a short Coachman which appears to be half ton towable. In the past I've pulled 32 foot campers to deliver them for friends.
I am thinking I will email customer support at B&W to see if they have any insight. I want to have this right before sinking holes into the box and frame.
I figured out the rails for the 5th wheel. I am also able to keep the gooseneck. The only thing I needed was a new set frame rails. I also had to fabricate a bracket to bolt it up to the frame. I ran out of time this morning.
When it is all said and done I can pull a gooseneck, 5th wheel and what ever pumper pull. And still have a toolbox in back.
Ahh, totally missed the shock mount rivets. I've put hundreds of 5th wheel hitches in but clearly didn't see those rivets in your pics.
Nice job.
Thanks. I normally don't post pics of my welding jobs. But good ol' stick welding with an older Lincoln I was proud of my work.
In hind sight another inch would have been better.
It was the same story with my old pickup. The first few turns were nerve racking. I might have to look for a new pin box to move it forward about 6 inches.
