Easy ways to make power in a 91 EFI 460??
cut out the ventures in the center of the air intake tubes or put on an aftermarket cold air intake. The biggest power reduction on these engines is the air intake and smog. Previous generations of the 460 made upwards of 500 hp getting anywhere near that you will need new heads and bored out cylinders at least. However, you can gain 5+ horsepower this way. I took out my air filter and went for a drive just to see what that would do and I gained a very noticable amount of additional power and torque. The angles and turns in the intake bring down the power a lot.
You can also make a decent amount of power with a slight ignition timing retardation and a performance camshaft. Maybe even 100 hp. That would likely also include new pushrods valves and valve springs for the additional lobe travel on the cam. None of this can be done in California or smog states obviously.
https://www.ford-trucks.com/forums/1...ree-power.html
The following users liked this post:
Air intake restriction on '97 F-350 with 460 FI...
I looked inside my airbox and there's no baffles or restrictions in there. These "ventures" that are mentioned in this thread, are they located in that "junction box" just before the throttle body, where the two intake hoses come together by any chance?
Big350
10-01-2006 08:54 PM
71F250CS
10-08-2002 10:06 AM
