torsion spring
Old Mar 6, 2016 | 12:23 PM
jdubsweb's Avatar
jdubsweb
torsion spring
All,
I have a driver side door lock that stays in a dropped position due to a missing torsion spring.
I've attempted making one from a version that my local Ace had. It was way to big.
I've tried using a magnet to see if it is still in the door.
I've tried many web searches.
Anybody have any McGyver ideas here?
Here is a photo of the passenger side:
https://goo.gl/photos/7yaahX8oD4biUy398
Thanks,
~bird~
Old Mar 6, 2016 | 12:29 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I've attempted making one from a version that my local Ace had. It was way too big.
Your profile says 1970 F100, is this correct?
Look at this upper parts catalog picture, give the number of the missing part. Is it 219A74?
Old Mar 6, 2016 | 04:58 PM
bajafishnut's Avatar
bajafishnut
I bet its in the bottom of the door, and removal of the door inside panel, should give access to it, unless it worked its way out a drain hole..?? I bet there is one, or more in a JY near you amigo.
Baja
Old Mar 6, 2016 | 06:49 PM
orich's Avatar
orich
And what would be the reason it came off~~broken..
Hit the PnP JY look for one other vehicles
Orich
Old Mar 7, 2016 | 10:20 AM
jdubsweb's Avatar
jdubsweb
The part list above doesn't even show that particular torsion spring
Part number 219A74 is way to big. This particular one has one loop in it. 219A74 is still in place.
It looks like part number 21872. Can I still order that part?
I recently purchased the truck. It looks like someone either got locked out or was breakin in. Someone drilled through the thumb press from the outside. That may have been the cause. Otherwise....well its from 1970.....
Thanks again guys.
~bird~
Old Mar 7, 2016 | 10:28 AM
NumberDummy
You're looking at the wrong pic, 21872 is only shown in the lower pic for L/LN & W series BIG trucks.
As I said in post #2, look at the upper pic for F series.
Old Mar 7, 2016 | 12:45 PM
bajafishnut
Perhaps it is the little spring shown in the assembly # 21952..?? Looks to be spring in that assembly?? At least, it could be, but the illustration is not quite clean on that part.
Baja
Old Mar 7, 2016 | 12:51 PM
NumberDummy
Originally Posted by bajafishnut
Perhaps it is the little spring shown in the assembly # 21952..?? Looks to be spring in that assembly?? At least, it could be, but the illustration is not quite clear on that part.
No spring.
21952 is the clip that retains the door lock rod and the rod from the remote control to the latch. Universal "fitz-all's" are available from auto parts stores.
Old Mar 7, 2016 | 02:32 PM
qman's Avatar
qman
You can't ask for McGyver ideas. You have to come up with them. What you're asking for are McGruber ideas.
Old Mar 8, 2016 | 01:00 PM
jdubsweb's Avatar
jdubsweb
I guess its the clip i'm looking for then. It looked like a torsion spring to me. From what I can tell that is what is different from the passenger side(works perfectly) to the drivers side.
So any auto parts store eh?
Old Mar 10, 2016 | 11:12 PM
JEFFFAFA's Avatar
JEFFFAFA
No. You are talking about the coiled spring Ford only serviced with the 21812 latch. You need to do some JY hunting or buy a replacement latch.
DAB SUNNY
41
Oct 27, 2023 08:39 PM
Elder Rodder
1947 and Older Ford Trucks
May 17, 2020 02:05 PM
Thoth88
Jul 3, 2018 09:23 PM
Ford1948F3
Jul 11, 2014 07:23 AM
