running rough IPR?
I did some research and changed the ICP because there was oil in the connector so even if it wasnt causing my issue i wanted to replace it.
Now I have the same issue but it will actually run a little longer and not stall. I thought it was fixed so i took it for a drive, after about 3 miles it bogged down and i was able to make it home with half throttle going about 30mph. Sounds almost like its running on half the cylinders. i unplugged the ICP and it continued to run that way.
I had done the 50cent mod a few years back with the peices from ford but i know the harnesses themselves can wear through so i checked the resistance between the center pin and the two pins to the right and left for both the injector harness and they had about 3ohms.
I am leaning towards an IPR but from the reading i have done it seams like most trucks will not restart after they die. I have AE so i am going to hook it up later today, just wanted some reccomendations on what to look at.
I also remember when i shut it off the unplug the ICP to see if it would clear up the needles on the gauges did a full sweep as if i disconnected the battery which i though was weird.
You'll need these, in order to do that:
1/8" NPT 90º elbow pressure port adapter.
Fuel rated Schrader valve for testing fuel pressure. Rated for Diesel or Gas.
The trucks will start again and run for a while at times if the IPR is bad. It simply has to cool off. Another thing to try is dumping some ice water on the IPR when the engine stalls and then immediately try to start it again. If it runs then that is another clue. Canned air turned upside down and sprayed onto the IPR will also work.
The fuel pressure test that the others have recommended is also valid.
I took it out for a ride this morning, at idle and under throttle it had 60-65psi. After about two miles the condition happened again but fuel pressure maintained the same.
I have done the 50cent mod with the Ford pieces, but maybe the harness is worn through.
Is there anything with the exhaust back pressure sensor that could be causing this condition? could one bad injector be the issue?
The IPR was at 750 and 15. Dont remember which was psi and which was duty cycle. The problem is it was running well so i should probably look at reading when it runs rough
It threw a check engine light this time and i received a P0113 intake air tem circuit high which i think is there because i have an aftermarket air filter. It also had P1316 injector driver module codes detected.
I did a buzz test and it said injector 7 circuit (cant remember if it was high or low). Pulled the valve cover and gasket and everything looks good. I will replace them anyway since i have to put it back together anyway and i have read other threads that had bad harnesses without visible damage.
The only thing that is unfortunate is I already removed the valve cover and harness and ordered a new one so I am going to wait and put it all together at once so I will not know what was the correct fix.
