Brake Pedal Pulse
Old Mar 7, 2016 | 07:56 PM
jhl3's Avatar
jhl3
Never mind x2
I guess the dude in the video could not help but to show the brake fluid reservoir since it is so close to the fittings and lines for the hydroboost..
Old Mar 7, 2016 | 08:21 PM
allenhillview's Avatar
allenhillview
Originally Posted by retiredsparky
I believe your problem is air still in the brake hydraulic system. Gravity bleeding cannot remove air that has gotten trapped on a high spot in the tubing. The fluid just flows past the bubbles of air (similar to what can happen to a cooling system).
A hand vacuum pump is more reliable or take to a shop and have them use a pressure bleeding system. Or you could try the time honored method using a person in the cab pushing on the brake pedal while you open a bleeder screw. The reason the pedal method works so well is that there is a lot of fluid flow, which takes the air bubbles with the fluid.
Larry
I did this very thing with the mighty vac just as I finished this brake job on each wheel,
Today I noticed it is about gone air has either surfaced or my helper and I got it with as stated the old tried and true method of pushing pedal as I opened bleeder closing just before pedal bottom. Thank you for the reply.
Old Mar 7, 2016 | 08:26 PM
allenhillview
Originally Posted by Zwalters
How does your power steering pump sound?
Quiet as it should!! Couldn't stand a noise, especially that Ford growl, LoL and thanks for asking
Old Mar 7, 2016 | 08:35 PM
allenhillview
Originally Posted by jhl3
Oh For Pete's Sake,
UM....Did you watch the video??? or read any of the preceeding posts??? before you responded? It is about replacing the the ATF in the hydroboost and power steering system......So, YEEEESSSSSS!
Yea I got that also in video, sure I would never put A/T fluid in brake reservoir as one thought I might be instructed to do, funny how we check ourselves. Thanks to the guy above who gave me Hydro flush link, I'm just getting now able to recognize a few names around the 7.3 forum, new to site. I was over at Steel Soldiers with a military CUCV for years. Thanks
Old Mar 7, 2016 | 08:50 PM
scotttahoe's Avatar
scotttahoe
Still fighting the same issue with my truck, going to bleed the system one more time tomorrow and if that doesn't help with anything I'm going to replace the brake booster. Will let you know if I come up with anything.
Old Mar 8, 2016 | 04:48 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Get speed bleeders and order the bag with hose. You will never go gravity again. You didn't put the caliper in upside down did you? It happens and will present with similar issues.
Good luck!
Old Mar 8, 2016 | 05:10 AM
allenhillview
Good luck!
Can never find that stuff when looking on www.
Old Mar 8, 2016 | 05:15 AM
AllaboutMPG's Avatar
AllaboutMPG
Speed Bleeder Bleeding Brakes Bleeding Motorcycle Brakes Automotive Bleeder Screw Brake Bleeder
I always to seem to be working on brakes when no one is home. These things make it much easier.
Old Mar 8, 2016 | 07:17 AM
F250_'s Avatar
F250_
Oh For Pete's Sake,
UM....Did you watch the video??? or read any of the preceding posts??? before you responded? It is about replacing the the ATF in the hydro boost and power steering system......So, YEEEESSSSSS!
I guess the dude in the video could not help but to show the brake fluid reservoir since it is so close to the fittings and lines for the hydro boost..
Alright... I stand corrected...
I had read all the preceding posts before responding, but my mind was sort of landlocked onto the brake system and just didn't connect the hydro boost dots into the discussion. Also, the IT gods have our network at my office locked up such that I cannot stream videos, and I'm such a penny-pinching data miser that I won't do it on my phone.
Old Mar 8, 2016 | 07:54 AM
allenhillview
Thank you for link
Old Mar 8, 2016 | 03:33 PM
retiredsparky's Avatar
retiredsparky
There is only one minor problem with the speed bleeders which is easily fixed. Brake calipers (especially ones that have been rebuilt at a factory) can have slightly oversized threaded holes for the bleeders. This possibly can happen from drilling out old rusted bleeders. This results in the speed bleeders having a loose fit in the threads. If the bleeder seems lose, to prevent air from being sucked in around the threads of the bleeder just smear a small amount of thread sealant at the threads after inserting the bleeder. You don't want to get the sealant into the braking system.
The sealant or grease on the outside of the bleeder is enough to prevent air from being sucked into the caliper.
Old Mar 8, 2016 | 04:19 PM
jhl3's Avatar
jhl3
It is all good...
Onesprint
Sep 9, 2017 04:38 PM
dsheffield
1997 - 2003 F150
Apr 7, 2014 10:53 PM
2112
Jul 31, 2012 10:43 AM
plessasrdjr
May 10, 2011 07:40 AM
Deiselman
Apr 4, 2007 06:42 PM
