Computer Chips & Tuners
webmaster :) help?
Old Aug 11, 2003 | 03:00 PM
DW2455's Avatar
DW2455
Smile webmaster :) help?
webmaster: the other day you ask for the code from my comp. i posted it but havn't responded as of yet thought mayb you forgot me anyway the number i found was (GU1) does that sound right ?
could or would a chip help my 87? Thnx DW
Old Aug 11, 2003 | 03:09 PM
FTE Ken's Avatar
FTE Ken
webmaster :) help?
Nope, haven't forgotten, you posted it twice. I was enjoying the weekend and I'm catching up right now. Neither Superchips nor Diablo has GU1 on file.
Old Aug 11, 2003 | 03:22 PM
DW2455's Avatar
DW2455
webmaster :) help?
sorry. does that mean there is no chip for mine or is that not the right number? Thnx dw
Old Aug 16, 2003 | 02:14 PM
fireguy50's Avatar
fireguy50
webmaster :) help?
No chip for that computer. Like I've stated don't waist money on a Truck EFI system. not worth the investment.
Old Aug 16, 2003 | 02:20 PM
DW2455's Avatar
DW2455
webmaster :) help?
We'll when i put my new motor in i plan on a mas air conversion, throtle body new intake, injector? What you think? DW
Old Aug 16, 2003 | 05:19 PM
fireguy50's Avatar
fireguy50
webmaster :) help?
you can keep the intake and throttle body if you want. the computer should be changed, injectors matched to your application, and harness re-wired to make it all happy
Old Aug 16, 2003 | 05:34 PM
DW2455's Avatar
DW2455
webmaster :) help?
IF it was carbed I'd have it made, The whole fuel injection thing is new to me. i've never modified an EFI before, I'm still trying to do my home work here as far as exactly what i need, but the plan is this fall im putting in a Aluminum head 351W, all ROLLER motor, and my goal is 400+HP 9.1 comp. run on pump gas , fuel injected daily driver. so any help you can offer on the (induction system) would be greatly appreciated. Thnx! DW
Old Aug 16, 2003 | 06:29 PM
fireguy50's Avatar
fireguy50
webmaster :) help?
Well for EFI education right now check out my site in my signature.
And if you get Bronco Driver Magizine then you'll be reading my stuff a lot more. For 400+ HP, 9:1 compression, ect you want to skip the Truck computer and swap in a Mustang EFI system. That might be enough for ya. If not there is a lot more EFI products for that computer and EFI system to help you out.
Old Aug 16, 2003 | 06:57 PM
DW2455's Avatar
DW2455
webmaster :) help?
Where i'm having trouble with is what size injectors? what size throtlebody? Thing like that. Where can i checkout this Bronco Driver Mag. I cant say i"ve ever saw one. Thnx DW
Old Aug 16, 2003 | 07:11 PM
DW2455's Avatar
DW2455
webmaster :) help?
hows that engine combo run? and what knida gas miledge do get if drive it right? DW
Old Aug 16, 2003 | 07:20 PM
oldblue18's Avatar
oldblue18
webmaster :) help?
www.broncodriver.com
EDIT: Hey Ryan (it's Ogeechee), hope you don't mind me jumping in on your thread
Old Aug 16, 2003 | 07:38 PM
DW2455's Avatar
DW2455
webmaster :) help?
Thnx For the link! P.S. Dont get out of line down there in statesboro ga. I'll have to get some kin folks to come straighten you out! i was born and raised out side of Augusta. been a MO transplant for 2 yrs now. DW
Old Aug 16, 2003 | 07:44 PM
fireguy50's Avatar
fireguy50
webmaster :) help?
Where i'm having trouble with is what size injectors? what size throtlebody? Thing like that. hows that engine combo run? and what knida gas miledge do get if drive it right? Thnx DW
Throttle body and intake only alter where the power curve is in the RPM range. The truck intake keeps all the power under 4000RPM with gobs of Torque
Gas Milage your kiding right LOL I drive a 6000lb truck with a lightning spin off engine and like to use the throttle
I get about 13MPG when I drive 95-100MPH for an hour to detriot LOL
Old Aug 16, 2003 | 08:02 PM
oldblue18's Avatar
oldblue18
webmaster :) help?
Me cause trouble??? No.... It is cool to meet people who know where statesboro is though. I usually have to tell people Savannah
Old Aug 16, 2003 | 10:11 PM
DW2455's Avatar
DW2455
webmaster :) help?
I understand on the intake, but wouldn't it need a bigger throtle body for more air to go with gas, like a larger CFM carb, or will stock TB handle the job?
P.S. other stipulation for the new motor im building is 15MPG under normal diving conditions. DW
