Sponsored by: Real Truck
Heat issues
Old Mar 3, 2016 | 09:48 PM
pskj8174's Avatar
pskj8174
Angry Heat issues
My '01 Super Duty 5.4 has an overheating/heater problem that the dealer can't seem to fix.
I noticed my heater was blowing cold then a few miles later it overheated pushing coolant out of cap. Next day drove fine to Ford dealer who replaced my heater core, thermostat, reservoir cap and a hose. Drove it for a day till the exact original symptoms occurred again with a gurgling sound in dash. Dealer kept for a week pressurizing system but no leaks found. Replaced my thermostat again and gave it back. I drove it 300 miles over a week before the exact same symptoms occurred. Brought back to dealer who said that air was in the system, added a bunch of coolant and supposedly got all the air out. Same symptoms still. Brought back to dealer that finally changed the water pump they said had a leak. Guess what, same symptoms. Heater will work fine for days then it will blow cold, then hot, then cold and sooner or later truck will overheat then just as fast cool down and heater will work again. Still hearing gurgling. Dealer said I don't have a HCV. Please help!!!
Old Mar 4, 2016 | 02:25 AM
02F250V10's Avatar
02F250V10
Sounds like it running very low on coolant. Any puddles under the truck after it sits? Could be head gaskets or a cracked head causing it to burn coolant if its been overheated a few times already.
Old Mar 4, 2016 | 06:35 AM
pskj8174's Avatar
pskj8174
I never see puddles and the reservoir is always mostly full until it pushes out some when overheating. The dealership swears its not a head gasket.
Thanks for your input.
Old Mar 4, 2016 | 06:40 AM
pskj8174's Avatar
pskj8174
I think it does have air in the system (the gurgling sound) which would also mean there is less coolant. I cant seem to get it out. I keep checking the reservoir and keep it at the max level.
Old Mar 5, 2016 | 05:53 PM
firebirdparts's Avatar
firebirdparts
It sure sounds like a head gasket. Getting the air out is not easy if the engine is pumping more in.
I guess you already know this, but you get an air bubble in the engine, and then it changes places and gets in the heater. That is where the air bubble is when the heater is blowing cold air.
If the head gasket situation is not sucking water in, then you wouldn't expect to have any water consumption. You would instead expect it to overflow at some point. however, there is no predicting how much stuff is going back and forth through the leak.
Old Mar 5, 2016 | 06:32 PM
khangmai's Avatar
khangmai
My guess would be the radiator. Run the engine until it gets warm, feel the radiator with your bare hand, if there is any ambient temperature tube between hot tubes, then your radiator is partially blocked, it must be replaced. Let us know what you find out.
Old Mar 5, 2016 | 06:33 PM
99f350sd's Avatar
99f350sd
Bad water pump? impeller gone.
Heater core needs good flow.
idealtrucks
2004 - 2008 F150
Jan 24, 2018 06:18 AM
Tulsamulerider
Jan 10, 2017 10:28 PM
offroad360
Jan 29, 2010 12:46 AM
hbkorkut
Nov 25, 2005 08:22 PM
rick
1997 - 2003 F150
Jan 11, 2000 10:05 PM
