Ford 460 Build Advice
Old Mar 3, 2016 | 08:50 AM
vinnydiesel27's Avatar
vinnydiesel27
Hi all, new to the forum..... I have a 75 highboy with dana 60s, c6 tranny and a floor shifter, 410 gears, and the best part, a 460 big block. I'm not sure what i want to do with it yet. At first I wanted to swap to a diesel but its too expensive and difficult to do. So, I think i want to build out my 460. Any advice on how to build out my motor? Looking for hp in the 500-600 range. Also should i go to fuel injection or stick with a 4 barrel. I need daly driver reliability. will efi be better for this?
Any advice appreciated... thanks!
Old Mar 3, 2016 | 10:24 AM
somethingclever's Avatar
somethingclever
i like fuel injection for a daily.
should be straight forward...tons of builds on google.
521+ stroker
performer rpm or scj heads
HFT in the 245 range
stealth or air gap or rubbed on rpm
950 or bigger TBI system
1 3/4 pri and 3" dual
that should make an ok truck engine with 525-550hp and cost about $9k from scratch
Old Mar 3, 2016 | 02:51 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
All depends on how fast you want to go and how deep your pockets are. If you think a diesel swap is to expensive, then you are like most of us, not filthy rich and work hard for our money.
I am not trying to offend any filthy rich people either, and I know that some filthy rich people get that way with lots of hard work and proper investments. lol
Alum intake, 4 bbl, straight up timing, cam and some headers. It also depends on what type of heads that 460 has as far a chamber restrictions and needing some head work done to compliment the headers properly.
If it is a dog now you might look into what axle gears and tire size you have. Some times a regear can wake a truck up.
Old Mar 3, 2016 | 02:55 PM
HIO Silver's Avatar
HIO Silver
There are links in the Engine section of the Tech Info Compilation for what ya wanna do.
Use the link below to transport your browser..........
Old Mar 3, 2016 | 03:07 PM
77&79F250's Avatar
77&79F250
Here https://www.ford-trucks.com/forums/1...l#post14955960
And here is a place to post that question. Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) - Ford Truck Enthusiasts Forums
Old Mar 3, 2016 | 03:20 PM
Sandgnat's Avatar
Sandgnat
Budget 460 Big Block | HorsePower | PowerBlockTV - Full Episodes I built this exact motor for my 79 4x4 and I love it. Take a look.
85e150's Avatar
85e150
All 460, all the time. You will not get 500 horse with bolt-ons. But, 500 is not that far out of reach:
460 Horsepower Chart (revised 1/24/09) - 460 Ford Forum
Note these are "serving suggestions" and ymmv. Good luck with it.
Old Mar 3, 2016 | 04:24 PM
HIO Silver's Avatar
HIO Silver
I bought the videos for $10 during their Xmas promo. Well worth it IMO.
Old Mar 4, 2016 | 08:43 AM
jbehuniak's Avatar
jbehuniak
I'm in the process of rebuilding a 460 to drop into my 78 F250. Realistically I may be pushing 300 to the wheels if not less. So far I have 5K into the engine, so 500hp is not that achievable on a budget.
My set-up is trickflow heads, a mild cam, weiland stealth intake manifold, edelbrock 800cfm performer, L&L fenderwell headers. The compression ratio is 10.29:1 with a 0.048" head gasket, it will be timed straight up, MSD ignition.
The biggest issue is you're putting this into a heavyish truck. A simple head, cam intake carb exhaust oil pump can bring a lot of power, but its north of 6000RPM and the cam doesn't start to build power until 2800-3500 rpm and it continues to climb. Before I'm done with then engine swap I will already be north of $7K. And the engine is at the machine shop.
Don't get me wrong, the 460 is more than capable of achieving 500 N/A horsepower and it can be done inexpensively. Just take into consideration that you don't want to throw small CC large port/valve heads on a worn bottom end.
A high HP/TQ engine:
800-1000CFM carb performer airgap intake or similar aftermarket heads (AFR/Trickflow/edelbrock/ford racing) aftermarket pistons and rods, full roller cam, balanced rotating assembly, ARP everything, block tested for cracks, line honed, decked for correct quench, atleast 9.5:1CR cam with greater than .600" lift at minimum, high volume oil pump. If you can stroke it then do that. Go onto summit and price all that out and see what it costs.
People will say that DOVE-C heads build a lot of power, and they do but you're limited to compression ratio of 9.5:1 max unless you really retard the timing or are running race fuel. Don't forget youre in a heavy truck and the engine will react to that and not a light mustang, timing is important.
If I could do it again and realize I'm already 3/4 to a 6BT swap I would of just don't the 6BT sawp, or done an EFI system with a turbo, which may be next years project.......
78Broncoinpieces
Jan 8, 2019 11:33 PM
OLDBLUEF250
Oct 22, 2016 08:42 PM
f1001969mike
1978 - 1996 Big Bronco
May 24, 2011 01:38 PM
leadmic
Apr 11, 2003 10:21 PM
