My 2002 Gears
Old Mar 3, 2016 | 06:47 PM
jamesbfishin's Avatar
jamesbfishin
Originally Posted by Allagash6.8
Yeah, 37" tires with stock gearing makes it feel like you're tied to a tree..
Dude you rolled your truck
Old Mar 3, 2016 | 07:08 PM
rockhounds4x4's Avatar
rockhounds4x4
I agree with the 4.88 gears, I've done a lot of research on which gearing I should go with on mine, and ultimately ended up buying the 4.88s, I will be installing them this coming week and will be taking time lapse video of the entire swap. Really looking forward to what it has in stock!
I assume you know what you are doing, but your post sounds like you are just going to do an easy swap.
Wanted the less mechanical to understand that setting up a set of gears is a delicate job with some fairly heavy knowledge required. you don't just swap them.
I have done a 5 or 6 sets with good luck, but i have enough knowledge to make myself dangerous and a decent tool and shop set up. There are life long professional mechanics that still hire others to do their gears for them.
Old Mar 3, 2016 | 09:19 PM
Allagash6.8's Avatar
Allagash6.8
Man that's just the good side...
Old Mar 18, 2016 | 10:07 PM
glockholiday's Avatar
glockholiday
Is it true you need a new carrier also to go to the 4.88's. I heard you could only go as far as 4.56 with the stock one. That's why I was going to go with the 4.56's to save a little cash.
Instead of putting the 4.56's in my V10 Excursion I just traded for the 4.10's that came in my F350 Dually with the 7.3 haha.
Old Mar 18, 2016 | 10:51 PM
Allagash6.8
I recently swapped my gears with the stock carrier I was still able to use 4.88s
Old Mar 18, 2016 | 11:11 PM
DeucesALLin's Avatar
DeucesALLin
My $0.02
I have done a fair amount of research and the price of factory 4.30LS axles is so low it does not make sense to spend the coin for anything else...
I would rather spend the money in rotating mass: lightweight wheels make a heckuva difference with the gearing.
I run 37" bias plys and lightweight rims on my 150-is rwhp, 4,000 lb jeep because they come out to the wieght of 35's... meaning my 5.14s spin them that much easier.
unsprung weight and rotating mass are huge factors.
Old Mar 19, 2016 | 09:12 AM
WE3ZS's Avatar
WE3ZS
I assume that you mean OEM 4.30 gear sets, and yes they are fine IF that is the gear you need. In my case with 35" tires and the heavy towing that we do I needed to go with deeper 4.88 gears.
Lightweight wheels are fine also if you can find them with the proper weight rating for the application. While towing my rear axle weight can get as high as 6600lbs, that motivated me to stick with very high quality forged hubcentric OEM 18" rims for my application.
I agree with how rotational mass will affect performance as I pointed out in post #4 above just be sure to keep in mind what some of those lighter weight options may be limited to.
Old Mar 19, 2016 | 10:48 AM
DeucesALLin
Absolutely.
Ask any man who has ever regeared ANY rig- and he will tell you:
Its like buying a new vehicle.
I am a HUGE fan of OEM wheels... not nearly as pretty but I have never broken one off road- unlike my pretty (pricey) aftermarket rims.
dewalters8886
Feb 17, 2017 10:29 AM
Vince79vette
Sep 30, 2016 02:05 PM
ajordan193
Modular V10 (6.8l)
Feb 5, 2009 07:04 PM
frankovsky
Oct 5, 2007 08:19 AM
Fishsimion
Mar 12, 2006 08:42 PM
