Sponsored by: Auxito
99 F150 multiple codes
Old Feb 29, 2016 | 06:13 PM
Christopher Walker's Avatar
Christopher Walker
I have a 99 f150 5.4 triton. It is showing 5 codes and i want to see if anyone might have one solution for all or where should i start.
P0174 system lean bank 2
P0303 missfire cyclinder 3
P0308 missfire cyclinder 8
P0353 ignition coil c circuit malfunction
P0401 EGR system insufficient flow
Thanks
Chris
Old Feb 29, 2016 | 07:08 PM
tsw902's Avatar
tsw902
Sounds like 2 of your COPs could be bad. try replacing cylinder #3 & #8 COP. If you can go a few days without the vehicle, order them online. If not I suggest BWD brand coils from orileys.
COPs = Coil-on-Plugs
Old Feb 29, 2016 | 11:07 PM
Bluegrass 7's Avatar
Bluegrass 7
Code 303 and 353 are the same cylinder #3.
The 353 indicates the coil is open, the connector is off or the harness is open.
The 308 is cylinder 8 secondary issue causing misfire failure.
The 401 code is a different issue unrelated to the ignition.
The 401 is a diagnostic test failure of the EGR system for flow rate.
It is a low flow test fail.
Could be the ports behind the EGR are plugged with carbon or the DPFE sensor has failed or both..
Good luck.
Bootlegger's Deluxe
Modular V8 (4.6L, 5.4L)
Mar 12, 2016 08:51 PM
BassFantasizer
1997 - 2003 F150
Apr 9, 2011 11:29 PM
playboy4aday
15
Apr 4, 2011 04:17 PM
mfraley65
1997 - 2003 F150
Feb 24, 2006 09:33 AM
keld
Jan 7, 2005 06:46 AM
