I've got a '97 F-150, 5.4 motor, 4x4 Off Road. All stock.
It recently started throwing codes that the EGR was stuck open. The way it drives it's either true, or a bad sensor is sending a false signal and fooling the computer.
It was recommended that I change the entire "EGR assembly". It's still the factory original and apparently there has been an issue them.
Does anyone have any good advice here? Should I put in a value and sensor, replace the entire assembly, or something else?
I have been around & around on this issue with my 2001 F150 4.2LV6. The consensus on that model from many mechanics who have posted on the internet has been that the EGR device itself on this type of Ford engine almost never fails, an EGR system fault nearly always resides elsewhere. Many amateur mechanics who have replaced the EGR valves (and who have posted about it) have said it was a waste of time & money, the DTC codes continued. If you search these forums, I think you can find some of these comments here.
I suspect the issue is similar in your engine, but the exact codes that you got are critical.
You need to get the code the system uses to tell what the failure is.
Then the system parts that involve the "test" failure are the first to look at.
What is the code?
Codes are a reference to specific test faulures so there are no false signals involved.
It's much more complex.
Recommendations are just guessing.
There is a sensor that when it fails it sends a code saying the EGR has low vaccum. Mine has failed twice. I also had carbon in the EGR assembly which a dental pic fixed nicely.
I have replaced the egr valve, dpfe sensor, egr vaccum regulator, and I have the throttle body off and I see no ports clogged. I continue to get this same code. Any advise on resolving this issue.
The 401 code is low flow when the PCM does a test of the system.
The DPFE is the sensor that reads out the results of the test pressure across a calibrated disc orface inside the metal pipe.
1. are the DPFE hoses on correctly?
2. is the regulator able to pass vacuum to the EGR so it will open when commanded?
3. do a test to see if the engine detects exhaust gas when you open the EGR a little with a hand vacuum pump. This proves the port is open or not.
4. inspect the hoses for cracks, splits etc.
. All there is to the system is vacuum to the regulator to be gated to the EGR.
Exhaust is present under some pressure at the exhaust manifold.
With normal intake vacuum, the combination normally flows exhaust gas toward the intake through the port when the PCM commands the regulator to allow vacuum to the EGR.
You must find the issue within these areas.
The DPFE should be a Ford part and not an aftermarket unit.
Sometimes an after market EGR does not work within Ford spec limits.
Good luck.
