So my check engine light came on this afternoon and after hooking up my scan gauge it showed the code.
In reading the bible I understand I should do either one of the following:
1. Disconnect the egr harness
Or
2. Replace the egr valve. If so where is a good place to pick one up and is a remanufactured one OK?
Which is the better option? My '06 has 141K on the clock.
