Tire recommendations
Old Aug 11, 2003 | 10:33 AM
beartracks's Avatar
beartracks
It's time to start thinkin about replacing the old tires. I've been abusing B.F.G. Radial T/As for years but would like to change to something with a little stiffer sidewall. Probably in 235r60x15 and 255r60x15.
I don't need an aggressive tread but like good straight line traction.
What do you guys like?
Old Aug 11, 2003 | 12:25 PM
tsokorai's Avatar
tsokorai
I'm very pleased with the Goodyear Wrangler AT/S 235/75R15. Nice water dissipation & traction on road, and for the little offroading that my 2wd allows, is more than enough.
Old Aug 11, 2003 | 02:15 PM
LxMan1's Avatar
LxMan1
Try the BFG all-terrain or the trail t/a. BFG has the best tires in the bussiness!!
Jimmy
Old Aug 12, 2003 | 09:29 AM
KJKozak2's Avatar
KJKozak2
I put a set of Bridgstone Dueler ATs on my not-ford truck about 1.5 years ago. Although I was happy with their traction and handling, I'm not at all pleased with their tread wear. They're almost bald after 25,000 miles.
I know a lot of things play into tread wear, but the first set of Goodyears I had lasted 50,000 miles under the exact same driving conditions.
Kevin K.
Old Aug 13, 2003 | 12:59 AM
neverenough's Avatar
neverenough
I've ran Goodyear's, BFG's, and Big-O brand tires on my 150. I ran 245 60 15's all around on matching AR-26 rims. Traction was ok, about the same with all the tires, maybe a little better with the Goodyear's, but, the cornering was always great. I take it you have some type of wider, aftermarket wheel to wrap those bad boy's around.
Old Aug 13, 2003 | 11:22 AM
beartracks's Avatar
beartracks
Well I'm getting some food for thought. The rims are 15x8.
The BFGs just seem to get "lumpy" feeling on the truck as they wear and I get a little horizontal movement with a load in the back. Never had that problems with them on a car. I already have sway bars so there isn't any lean just sort of a yaw feeling.
Getting the same sizing may limit my on the tires selection.
Old Aug 13, 2003 | 11:42 AM
Ecuri's Avatar
Ecuri
For a "bargain", I really like the NTB 'Viper TR' 275/60 R15 on the same 8x15. This is a comfortable, quiet tire on the highway. Sticks really nice around corners, and I guess I'm getting around 40K out of a set. The compound is quite a bit softer than the TA and easier to 'catch' in a slide. (Not such an abrupt loss of traction). I am on a lot of construction sites and the NTB road-hazard has payed for itself many times over. They run about $80.00 a copy. They are usesless in any kind of mud, they load up fast and hold it. I usually go with an 'S" rated as I spend a lot of time near or over 80 MPH in very hot weather, but have had no problems with this 'R' tire. (4+ hrs at over 100 in west TX). No, I do not own stock in NTB!
Old Aug 13, 2003 | 01:38 PM
beartracks's Avatar
beartracks
Interesting. But what is NTB? I haven't heard of them. One prob I have on the back is I can only run 20 psi or so. Since there is normally no load the 275s wear out immediately in the middle!
Going to a 16" or 17"rim isn't out of the question. Don't know if I would like the look.
Old Aug 14, 2003 | 04:29 PM
Ecuri's Avatar
Ecuri
NTB is National Tire and Battery (recently purchased by Sears)
I am sure the tires are made for them by who knows?
I run the full 44 PSI and have even wear. GL
Old Aug 14, 2003 | 08:53 PM
theonlybull's Avatar
theonlybull
personaly, i love cooper tires... great traction, good price, and a all around good workin tire
Old Aug 14, 2003 | 09:17 PM
Matts72's Avatar
Matts72
I like the Pirelli Scorpion A/T's. Check the www.tirerack.com they usually have a decent recomendation.
these are the tires
http://www.tirerack.com/tires/Compar...elli&x=13&y=18
Old Aug 15, 2003 | 05:57 AM
79_250RangerLariat's Avatar
79_250RangerLariat
Go with the Coopers! They've lasted me longer than any other brand of tire.
Old Aug 15, 2003 | 09:04 AM
richardmb's Avatar
richardmb
I second the Cooper tire vote! I'm very impressed with the wear, and traction from mine.
Old Aug 15, 2003 | 01:38 PM
Ecuri's Avatar
Ecuri
found out Cooper makes the Viper for NTB!
Sure like those Cooper's!
Old Aug 16, 2003 | 01:09 AM
RednekFord's Avatar
RednekFord
Most people I know had the best luck with Goodyear MTRs....better traction and simply more versatile (on and off-road) than ATs.....that's what I'm about to be putting onto my truck as soon as 37x15x12.50s get off of backorder
