problem changing engine bay fuel filter
Old Feb 28, 2016 | 11:08 AM
gsxr1300's Avatar
gsxr1300
I was changing the engine bay fuel filter and the fuel line in the rear has 2 connections with a line going down and the hose came off the connector and seems to have broken off.
Has this this happened to anyone else?
Old Feb 28, 2016 | 11:13 AM
gsxr1300's Avatar
gsxr1300
Old Feb 28, 2016 | 12:04 PM
gsxr1300's Avatar
gsxr1300
found a replacement part BC3Z-9B246-A
Old Feb 28, 2016 | 04:13 PM
Iowa Ford's Avatar
Iowa Ford
I have seen that same problem on here before. The last guy found the same part and fixed it himself, I believe.
Glad you got it fixed
Old Feb 28, 2016 | 04:38 PM
gsxr1300's Avatar
gsxr1300
Thanks Its not fixed yet but I ordered the part its just dead in my driveway.
Old Feb 29, 2016 | 05:35 AM
glsurratt's Avatar
glsurratt
The dealer broke mine off. They said it was a common problem.
I don't understand why Ford would use plastic for parts that are sitting right on top of a turbo that is going to heat up to 1200 degrees or more. The constant heating/cooling cycles are going to make the plastic brittle to where it eventually breaks.
Old Feb 29, 2016 | 05:44 AM
gsxr1300's Avatar
gsxr1300
I am only at 40k miles too.
frank5079
Oct 28, 2019 10:25 AM
Hotpocket
Nov 12, 2012 08:57 PM
2002exPSD
33
May 16, 2011 11:29 AM
beforeiforget761
2004 - 2008 F150
19
Feb 29, 2008 12:05 PM
