Likely a dirty radiator. The airside can get pretty nasty. I was seeing similar temps (210-215F) climbing long 6% grades a bit south of you (Hwy 180 into Kings Canyon), also unloaded. Towing it ran 220-225 with the fan screaming.
Air side looked ok from the top, but once I pulled the rad it was impacted all the way thru, especially down at the bottom. Tried flushing with a hose nozzle and dropped the temp a few degrees unloaded. Towing was the same.
Got a new radiator and my ECT now runs 195-200 unloaded on the same hill depending on how much I get into the go pedal.
I am pulling the radiator as soon as I have a free weekend. Performance sells an all aluminum radiator for $219 that is supposed to be the same one sold by BPD. I am hoping that ED from FICM Repair will have a lead on a good radiator.
I figure pulling the radiator to clean it is good preventive maintenance.
BTW, I own an E150 van in addition to the diesel van. I drove it in 90 degree weather up the grade to Kings Canyon and it never got over 190 degrees. I am planning a trip to Death Valley in the diesel van this spring and want to get the cooling problem resolved before I hit any major grades. $219 for a radiator is about $50 more than what I payed to fill up the E150 van when gas hit $4.50 a gallon!
Wow that's cheap! A stocker from Tousley is $260. Curious on the build quality. The might be shorting the number of tubes, fins, etc
After getting a freight-damaged radiator from Tousley and them not recommending shipping another, I ended up buying a radiator locally from a dealer. I think I ended up paying around $375 and I was able to inspect it before leaving. Good as the first one I found was bent. Ford really needs to package these things better...
I was wondering about the build quality. I heard about Performance on the Sports mobile forum. I called BPD and they said they get the all aluminum radiator from Performance.
OEM style replacement are.about $200 at local parts shop. They all have plastic. I don't need an all aluminum. I need one that cools.
I don't think there's anything wrong. When I pull the 6% Camarillo grade or the long grade out of Indio going east, pulling my trailer, I see 220 ect and my fan kicks in and drops it back down to about 210. Ect's will show between 12-18 degrees when pulling, 7-10 degrees without.
You are in cooler weather but higher elevation and even with the turbo, I'd expect to see similar results unloaded.
I wouldn't spend the money.
I have checked various forums and have concluded that my experience is normal. I did a visual inspection on my radiator and it's Ford OEM and does not look old.
I purchased a $2.50 spst toggle switch on Amazon and will use it as a fan clutch over ride switch. Various folks have used this mod to cool things down when climbing a grade or towing a load. It will cost about $50 after I buy the soldering kit and wires. I need the soldering kit to complete my house battery wiring.
I am adding BG Super Cool to my fresh coolant flush.
While I am on this topic has anyone changed the serpentine belt on the 6.0 van?
Yes I've done it. It's a while ago but I do remember it wasn't so much fun. If your arms are skinny and long like mine it's not too difficult to tackle though.
My arms are skinny and long. I am 6'0" and still weight about 180. Do I have to remove the fan shroud? I would rather remove the easy low hanging fruit than trying to snake my skinny arms through a maze and jungle.
I did my belt by myself only removing the fan shroud, I don't consider it bad at all, took me all of 5 minutes. Not sure why everyone's removing loads of stuff
5 minutes? I bet the Stealership charges over $200.
I love low hanging fruit repairs. I am 4 times slower than the average shade tree mechanic. Give me at least 20 minutes for this repair after I remove the fan shroud.
5 minutes to change the belt On a 6.0 van? I'd like to see that.
