Sponsored by: Real Truck
is suspensions compatible
Old Feb 24, 2016 | 07:54 PM
97f2507.3psd's Avatar
97f2507.3psd
I got shocks off of a friend that owned a 2005 f350 6.0psd and I currently own a 97 f250 7.3 psd and I would like to put the shocks from his 05 on my 97 would like some input to c if they would fit and what adjistments I would have to make do I need anothe pitman arm which I believe I do bit what size? Also he gave me an electric fuel pump from his 05 I would also like to install that on my truck as well I have an inline filter which is only single canister I was told it was off of a tractor filter looks a lil short but can I add a larger filter to it and will this set up work for me?I also have another question my truck sounds like it is surging a lil bit I cleaned out fuel bowl and ipr screen added new exhaust back pressure sensor and icp sensor sodered wires the right way my ipr numbers which is about 575psi are eratic it jumps from around 575psi %-635psi%around my ipw injector pulse width also isnt steady fluxuates 10 didgets back and forth just like my ipr any input would b appreciated thank u
1red911
Jan 19, 2007 03:10 PM
05f250powerstrok
Mar 16, 2006 03:14 PM
Tazzmann
Jan 5, 2005 07:54 PM
noluckatall
Jul 20, 2004 01:07 PM
