Mirror upgrade
Old Feb 24, 2016 | 05:53 PM
DirtyDieselSMS's Avatar
DirtyDieselSMS
Mirror upgrade
Guys sorry if this has been addressed before, and I appreciate anyone that's gone before me to provide the R&D on this... Has anyone been able to buy the 08+ mirrors (cheaper set ~$200) off of eBay and had success in all electric functions out of the box? Or... Is there a way to get into the mirror and replace the wiring itself with the harness from our factory mirrors? I've got the stock 2005 tow mirrors on my Ex, and bought a set like I mentioned above. I'm sorta impatient and want to make the ones I received work if I can. Thanks!
-shannon
Old Feb 24, 2016 | 05:56 PM
hav24wheel's Avatar
hav24wheel
DEDC are the cheap eBay mirrors I have in the 08 style. Not one issue with function of any of the wiring for me. They are good for the price
Old Feb 24, 2016 | 05:58 PM
DirtyDieselSMS
Do they have full power, heat, signal functions also?
Old Feb 24, 2016 | 06:07 PM
Skip1970's Avatar
Skip1970
I got the Chinese made ones from twitchy. Cut plugs off originals and installed on 08 mirror's worked good
Old Feb 24, 2016 | 06:10 PM
DirtyDieselSMS
The harness included with the mirrors I got doesn't plug into my vehicle harness. My Ex is a Limited with heated glass and memory function. I can lose those 2 functions as I live in Texas, but would like at least power adjustable.
Old Feb 24, 2016 | 06:11 PM
DirtyDieselSMS
Originally Posted by Skip1970
I got the ching chong ones from twitchy. Cut plugs off originals and installed on 08 mirror's worked good
Would you mind telling how you accomplished this? I'd really appreciate it!
Old Feb 24, 2016 | 06:12 PM
hav24wheel's Avatar
hav24wheel
Yes the ones I got had full function, heat, signals, and marker lights. On my old ex I had to wire in for the markers, but everything else was good. On my F250, I had to wire heat, markers, and signals in...
Old Feb 24, 2016 | 06:13 PM
Skip1970's Avatar
Skip1970
Mirror upgrade
Just get diagram from 08 and your year and swap them around. It's on fte search
Old Feb 24, 2016 | 06:49 PM
PSUhoss's Avatar
PSUhoss
Might want to give these a look, I really like mine as do others.
2002 Ford Excursion Power Heated Smoked Style Signal & Clearance Light Textured Black & Chrome Caps Towing Mirror Upgrade Pair at 1A Auto.com
Old Feb 24, 2016 | 09:08 PM
HiZ's Avatar
HiZ
Anyone upgrade to power folders on a 2000 where I need to pull power for the signal full power for the running lights and pull power for the powerful anybody have a sweet simple way to do this
Old Feb 24, 2016 | 09:49 PM
DidieX's Avatar
DidieX
I did this on a 2002. Only difference is 2002 has turn signal wire already. I needed to add the wire for running lights (I tapped it from behind the main light switch, I think it was the brown wire). And if you get it from 1AAuto it includes the wiring, harnesses and switch for the power fold so it's plug and play. Just pull off the door panels and run the switch to your location of choice. Then tap it off of something for power or use the included add-a-fuse thing-a-ma-bob. Also, I think the 2000 has an older style connector for the main mirror wiring harness but I'm pretty sure it came with an adapter for it in the box. It's really not that big of a job, took me an hour or two.
Old Feb 24, 2016 | 10:39 PM
Stewart_H's Avatar
Stewart_H
For all the guys asking questions, please don't forget to read the info found in the tech folder.
Stewart
Old Feb 24, 2016 | 11:14 PM
HiZ's Avatar
HiZ
Agree, tech folder is the best.
Reps for this update on where to tap in. I have the power harness with instructions for you to read, me, so reps on the motivational talk. That's what i needed. ....
Old Feb 25, 2016 | 06:11 AM
hav24wheel's Avatar
hav24wheel
Easiest place I found to tap for signals is behind the cluster. The wires that go to the signal indicators. I can't remember off hand what color the wires are though.
Old Feb 25, 2016 | 10:54 AM
DirtyDieselSMS
I've been searching for a couple of hours, and I can't find a correct mirror plug diagram for an 08+ truck. I'm wanting to cut my factory plug off my mirrors and splice to the mirrors I bought on ebay. FWIW I got power, heat, signal mirrors. Thanks.
