Vent Window Pivot Post
Old Feb 24, 2016 | 05:17 PM
daveengelson's Avatar
daveengelson
Currently installing the door weather strip kit, in the process of removing the vent window from the frame the window pivot post broke away from the frame, I intend removing the glass to determine if I can rivet a replacement in it's place.
My question: searched various Ford part supplier's and although not a particular fan of LMC it appears they are the only supplier who offers the vent window pivot post? Thought I would check to see if a member(s) have experienced with their replacement, seems $20 is kinda pricey??
Comment, Suggestions appreciated!!
Old Feb 24, 2016 | 08:49 PM
bphirt1's Avatar
bphirt1
Hello. I had same issue a few weeks back on my drivers side, but mine was broken off when I bought my 66. From what I found was that no one sells the pivot post because it is part of the frame. You have to buy the frame from a place like LMC. Then you have to get your original glass out which might be worth buying a new one because it is cheap. I was lucky to find a used one with glass on eBay. Mine was also missing the pivot arm which no one makes. I was able to get that part from one of the members on the site. Hopefully someone else on here has better news.
Old Feb 25, 2016 | 12:31 AM
daveengelson
Appreciate the information. On a number of occasions I have found what the Ford part supplier has listed in their catalog does not mean they carry the item. Rather than pay for the vent window frame I was hoping to purchase just the pivot post; referring to item #6. I placed the item in the cart but Intend calling them tomorrow to confirm? It has been several years since salvaging the vent window pivot post on my other 65 and seem to recall had a heck of a time figuring out how to get the rivet to anchor the post to the frame, worry about that if able to obtain the part.
Again, I thank you!
http://www.lmctruck.com/icatalog/fb/865w/0019.jpg
Old Feb 25, 2016 | 06:07 AM
bphirt1's Avatar
bphirt1
Again, I thank you!
My fault. I was talking about the part that is attached to item #1. It is part of the frame where the swing hook sits in. Good luck
Old Feb 25, 2016 | 11:19 AM
daveengelson
Not a problem!!
For info purposes: Spoke with LMC sales person and confirmed they did have the item in-stock. Decided to hold off on purchasing the pivot post, fairly certain I will be able to salvage a spare but I did purchase the other vent window components.
my 66
Dec 18, 2015 12:18 PM
eddie201
Jun 11, 2010 08:10 PM
65f100pdx
Aug 1, 2008 11:58 PM
77' f-100 ranger xlt
Jan 24, 2006 03:39 PM
