Fuel Pressure Issues.
Old Feb 25, 2016 | 06:11 PM
white Buffalo's Avatar
white Buffalo
In the past you mentioned a leak at the drain valve, get those O-rings changed out?
Old Feb 25, 2016 | 10:42 PM
Baatzy's Avatar
Baatzy
Haven't done the drain o-rings yet, but watching where I park, the truck doesn't seem to be leaving "droppings" anymore, and the smell of diesel has faded again, so I think the leak is pretty well back under control, although I can pop the hood and take a look in the morning.
Baatzy
Old Mar 6, 2016 | 11:17 AM
Baatzy's Avatar
Baatzy
Finally got some time to work on this. Have done some troubleshooting this morning but I have a couple questions. For those of you with a FP gauge, when you are at KOEO, FP running what pressure does your gauge display? I am running the 61-65 psi spring in my FRx and mine will pump up to about 55-58, then slowly, or extremely slowly bump up to that 65 psi at idle. Also, what voltage should I have across the pump? KOEO I am around that 11.5, KOER GP off it slowly climbed to battery voltage, but it took a good 30 seconds to get it there. Throughout the climb, torque pro was giving Vbatt at 14.3 volts.
I removed the input hose to my frame rail filter and put on a hose into a 5 gallon can and nothing really changed in behavior of the FP gauge, so I don't think I have tank issues. I am going to now bypass the frame filter and go straight into the pump and see what happens while I wait to hear back.
Thanks to anyone up and perusing the forum on a Sunday morning.
Baatzy
Old Mar 6, 2016 | 11:39 AM
Baatzy's Avatar
Baatzy
OK, what the hell? I just bypassed the filter and hooked the 5 gallon can and hose assembly straight into the back of the pump, FP gauge went to zero, and stays there. Truck sat and idled for at least 5 minutes though, plus numerous pedal to the floor revs. Fuel pressure stayed at 0! Only side effect is that the truck seems to have more of a growl in the idle.
What on earth?!? 1 month old FP sender take a crap?
Baatzy
Old Mar 6, 2016 | 11:41 AM
AllaboutMPG's Avatar
AllaboutMPG
Got any way to run 12 volts directly to the pump and see what it does?
Old Mar 6, 2016 | 11:45 AM
Baatzy's Avatar
Baatzy
Paul, I can give it a try. Is there any easy way to get the wires disconnected? Pain in the butt getting to it to measure the voltage.
Baatzy
AllaboutMPG
Don't feel bad. I went with Glow shift to save money and am on my 3rd FP sending unit. Finally got mine mounted vertical and remote, no more problems.
Old Mar 6, 2016 | 11:48 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Baatzy
My gauge immediately goes up to about 60, then takes another second or two to get up to 65ish. Then running down the highway it stays pretty steady around 65 psi.
AllaboutMPG
Not real sure about how to go about wiring it. It would be nice if you had a something laying around with pins that would fit and you could just disconnect the factory plug temporarily hook it up.
Old Mar 6, 2016 | 11:56 AM
Sous's Avatar
Sous
FTE Emeritus
Baatzy, I had some problems with my new ISSPRO FP sending unit after installing. Please see the details here.
Basically, the pressure from the pump destroyed the sending unit due to rapid pressure changes. Once that started to happen my gauge began reading higher and higher and then went to zero. You can see the picture of the "fix action" ISSPRO sent me. They claimed it was a fairly common problem on the earlier model 7.3 Powerstrokes.
This might shed some light on what you are going through.
Old Mar 6, 2016 | 12:21 PM
Baatzy's Avatar
Baatzy
So, in the thought of "my truck is the weirdest damn truck I have ever worked on or heard about" mindset I went out and plumbed the tank to the FP, bypassing the frame filter. My FP gauge works again. Sitting right at that 63-65 psi idle. I'm going to go take it for a drive and see how it acts.
I can already tell you its not going to change though.
Anybody looking for a truck?
Baatzy
Old Mar 6, 2016 | 06:33 PM
Baatzy's Avatar
Baatzy
As I guessed, plumbing to the tank but around the filter didn't fix anything, acted the exact same.
Said a bunch of words that can't be repeated on a family forum and decided to drop the tank. Found the feed line showed characteristics of a kink, vent lines were disintegrating. Did the necessary fixes, routed the feed line so it shouldn't kink at all and put the tank back in. Somehow got my fuel gauge to read permanently full. FP acts almost the same as before, just takes a little longer to drop, and idles a little higher than normal.
Got a new fuel pump supposed to arrive tomorrow, going to swap that in and see what happens.
Baatzy
Old Mar 7, 2016 | 12:18 AM
  #28
white Buffalo
Sorry I didn't get a chance to return your call Ethan - we've got the flu bug here, been running around fetching nyquil, helping with homework, chasing the dog.........I sat down for a minute & passed out on the couch and before I knew it, it's 11:30 pm
Old Mar 7, 2016 | 12:32 AM
  #29
Baatzy's Avatar
Baatzy
Don't worry about it, I spent most of the day under the truck goofing around anyway. However, on a follow up to that, I will be headed home Wednesday of this week, looking to hit SF about 12, give or take. So if you were free and interested in meeting up then, otherwise Thursday is currently free for me as well if that would work. Let me know in whichever way works.
I'll post back after flipping out fuel pumps tomorrow, also, on another note, the fuel level gauge decided to start working again.
Does my truck know I look at 6.0s?
Baatzy
Old Mar 7, 2016 | 12:52 AM
  #30
white Buffalo
You'll get her figured out man - only a matter of time. Give me a shout on your way back......
I should be around Wednesday.
you probably just got that fuel level float stuck a bit, then driving her around she dropped back into place.
