CPP hood tilt alignment (pics)
Old Feb 24, 2016 | 04:46 PM
jrockdiddy's Avatar
jrockdiddy
Hood fits pretty good, except for the middle where it meets the cowl. It's a little proud (first pic) any ideas?
Old Feb 24, 2016 | 07:03 PM
gerrymoe's Avatar
gerrymoe
There is an angle right on the center of the support brace that goes across from hinge to hinge, cut that and adjust and reweld. But might want to address the oil canning in the center of that hood first. The gap between the fender and hood can be shortened by loosening up all the bolts from fender to air deflector and push the fender towards the hood and have someone tighten bolts while someone holds the fender in the desired position. If that does not work might have to elongate some holes in air deflector.
Old Feb 25, 2016 | 07:53 AM
jrockdiddy's Avatar
jrockdiddy
Thanks, the hood has a pretty good dent in the front right in the apex of the point. Not sure if I"m gonna use this hood.
AXracer
26
Jul 29, 2023 10:54 PM
Trentonpro1
Feb 11, 2018 01:26 PM
Mercman54
Dec 4, 2017 10:57 PM
Samorkand
Nov 10, 2016 07:55 PM
zpmps2
Nov 25, 2007 09:48 PM
