Y-pipe to turbo hell
If they're in with the 13mm nuts on top it's a REAL PIA. Mine are turned with the 10mm bolt head on top so I can use a 10mm flex head gear wrench to let it lock against the pipe as I unscrew it from the bottom. A blue tip wrench comes to mind in your situation.
So I had no luck with loosening the bolts at the manifold HOWEVER I loosened the pedestal bolts and it was easy as Pie to mate the turbo to the y-pipe! This will be my preferred method from here on out for sure!
The bad news is that I'm still overboosting with a totally different turbo... I saw an EBP sensor circuit intermittent code but I've ran with a bad ebp before I thought with no issues. It's an 04.5 btw so the ebp is not inferred (I don't think). I guess I'll try to change/clean that again for the second time this year.
My vgt% used to be 40%-60% and now it's 55%-75%. I'm carefully feathering the accelerator to not go over 25 psi boost while driving. I have Good maf readings and map just no ebp. Maybe my actuator dowel rod is is 1 tooth off for both turbos? My last turbo was stuck and I romped on it to brake it free with high temps. It freed it but thats where my problems began.... I'm wondering if I punched a tooth out. I thought I had this licked but I'm right back where I started. Right now i'm experiencing the bittersweet feeling of "close but no cigar" as I'm sure all of you have felt.
All help is appreciated
-Dick
-Dick
I ran 70 miles a day for two weeks running 20 to 28 lbs of boost. Other then the mpg being cap it ran pretty good
NOTE: I knew I was putting it in the shop
I know how you feel too. Cleaned the turbo and still had the problem--on mine I haven't found out yet what it was.
Yeah it actually has awesome giddup and go, it just sounds like a jet airplane to the point of people looking. Yeah mpg's are smashed.What did you do with yours?
Put it in to get hg done. But the turbo thing started when my ebp went bad from getting soaked with coolant. No problem I'll unplug it like I did last time and it will fix it. It didn't (runs off of default) so I pulled the turbo and cleaned it. Put it back in and same problem only acted different. Vgts had a mind of their own so I just left it to let the shop figure it out. Plus side I have a rebuild kit on hand if I need it as the turbo had no bad seals. I was suspecting a bad vgt or unison ring (just the place where the actuator pin moves the ring) but we'll see. I did have them put in a new vgt pig tail,ebp,and ebp pig tail.
-Dick
-Dick
FYI for loosing nuts and bolts use the PB Blaster,Kroil or the DIY
transmission fluid and acetone mixture. WD40 is really useless in
for this application. You want something to penetrate.
The first time I ever R&R a turbo I used the instructions in the Ford
shop manual and some advise from SrMasterTech. It came out easy
and I only a bit of trouble getting the drain seated right the first time.
Once I had that done all the sealing surfaces lined right up and sealed.
Turbo clamps first and then the up pipe bolts.
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
-Dick
-Dick
P0472
P0473
P0470
P0299
When I get the P0473 (ebp valve fail) the vgt goes to straight to 15% (open vanes). Vgt returns after restarting the truck. I checked the ebp sensor and tube. No obvious chafing on the pig tail but looks very old. I have removed the mount for the old style ebp from the thermostat because I accidentally bought a newer style ebp sensor 2k ago and had to thread directly into the 1/4" tube. Since the mount is gone, I think it may have vibrated itself bonkers.
I should also mention that this turbo is freshly cleaned and is from another vehicle with 50k on it. I find it odd that the same thing is happening with 2 separate turbos. Maf readings are normal as well as baro and IAT. My edge has never read EBP values but I will check with AEP and cycle the vgt% later.
All thoughts are appreciated!
-Dick
#30
Just wanted to see if anyone had any ideas here. I now have the following codes
P0472
P0473
P0470
P0299
-Dick
P0472
P0473
P0470
P0299
-Dick
