squeak
Feb 22, 2016 | 04:45 PM
squeak
got a bad squeak, changed belt twice, new tensioner, new alternator, the pulley on the power steering pump goes in and out about 3/8 in with belt off. did the stick to ear on all things to belt, cant find squeak. any ideas? thanks Capt. Hugh
Feb 22, 2016 | 04:47 PM
Feb 22, 2016 | 05:01 PM
Have the same problem with my 302 on my 88. Changed belt twice,tensioner pulley, new alternator, new power steering pulley.
Try putting soap on the belt with the engine running until you get the issue fixed. Stay away from the fan while you do this
Feb 22, 2016 | 05:55 PM
Check a/c pulley, had same problem , turned out to be outer bearing .
Feb 22, 2016 | 07:22 PM
Take the belt off and see how the air pump(smog pump) spins,my 91 squeaks sometimes.
Feb 23, 2016 | 11:16 AM
squeak
thanks D Hill the soap worked, with the belt off cant turn the smog pump by hand, should it turn by hand? thanks guys
Feb 23, 2016 | 11:28 AM
Quote:
Originally Posted by
Selfhl1
Sounds like the smog pump has seized up if I'm not mistaken.
Feb 23, 2016 | 11:32 AM
squeak
not locked up but turns hard, should it spin freely
Feb 23, 2016 | 11:38 AM
Selfhl1
Yes all of your pulleys should spin freely by hand with the belt off.
Big Skier
31
Feb 27, 2019 07:21 AM
reggiedunlop
1983 - 2012 Ranger & B-Series
May 28, 2017 11:48 PM
Joe Boz
Jan 23, 2005 12:35 AM
customx
15
Jan 18, 2005 02:06 PM
kinnja
Sep 3, 2004 12:27 AM
