I used the spacer kit that takes the place of the crush collar. I set pinion preload to 30 inch/lbs with a dial torque wrench, and measured backlash at .012.
Correct me if I am wrong but isn't the pinion preload suppose to be around 12 inch/lbs not 30.
Did you use assembly lube ?
You may luck out short term .
If it got hot enough to sizzle .... Damage done .
I have built Many rear ends over the years ..I think you will have issues .
Best of Luck !
Thanks; and yes I used assembly lube, I have a couple extra carrier bearings I was going to use in my other truck, maybe this week I will put them in just to be on the safe side
